My Linksys USB Wireless network adapter flashes the it would work better plugged into a 2.0 USB Port. Does this motherboard support it? Can you plug in additional USB ports with a 7 pin connector on the board & where?
SOURCE: USB port installation
NavajoGirl,
I have a Jetway 663AS. The USB Header is J5 and is a 10 pin connector with 1 pin missing. It can be found near the battery.
HTH,
Paul
SOURCE: Mouse Doesn't Work in PS/2 port
CHECK BIOS TO MAKE SURE IT DID NOT TURN ITSELF OFF WHEN YOU PLUGGED IT INTO THE USB.BIOS MAY HAVE TURNED IT OFF TO PREVENT A CONFLICT.RICHARDM69
SOURCE: i need the manual for a soyo sy-kt400 dragon lite motherboard
Hi freebird2k6,
Go to this Soyo link:
http://www.soyousa.com/content/Downloads/155/&c=35&p=173&l=English
Drivers, bios & manual located on this site.
Manual is at the bottom of page. (Soyo no longer supports the board so download everything & burn it to CD).
Soyo may stop listing these drivers soon.
Mike
SOURCE: I have a msi ms-7399
Looking in the net I found someone running an E8500 on this board so I guess an E8400 will work fine.
SOURCE: Hooking up Front USB Port
the red wires go on the side that is not missing a pin.
in this scenario, 4pin goes on top, 5pin on bottom, red wires on left.
in this, 4pin on bottom, 5pin on top, red still on left.
i wont show you the reverse of that because you should understand and i think the formatting on this page will screw it up.
