I have a msi ms-7399 motherboard. Its a stock board in a gateway dx4720-03. these are the only specs I could find for it. Supports Intel dual core processors Nvidia chipset Two DIMM slots dual channel DDR2 memory Integrated Nvidia graphics Integrated Realtek Audio Integrated 10/100Mbps Ethernet LAN Four internal Serial ATA (SATA) device connectors One IDE Port Internal One Floppy Drive Port One external eSATA port Four add-in card slots: One PCI Express ×16 (graphics interface) Two PCI conventional One PCI Express x2 Specifications: Form Factor Micro ATX Board Size 9.6 × 9.6 inches Processor Support Intel Core2 dual core processors Chipset Nvidia Memory Support Two DDR2 DIMM slots dual channel memory Video Integrated Nvidia graphics Audio Integrated Realtek Audio Network Integrated 10/100Mbps Ethernet LAN Add-in Card Slots One PCI Express ×16 (graphics interface) Two PCI conventional One PCI Express x2 Internal Connectors One 24-pin ATX interface power One 4-pin ATX interface power Four SATA One 4-pin speaker 3 10-pin USB (2 × 5 pins) One 10-pin 1394 (2 × 5 pins) One 4-pin CPU Fan One 4-pin SYS Fan One 3-pin CLEAR CMOS Rear I/O Ports One PS/2 keyboard port One PS/2 mouse port One VGA port One Serial port Four USB 2.0 ports One RJ45 LAN port One IEEE 1394 port One eSATA Six Port Audio I want to know if it will reconize and handle an lga 775 E8400?
    Sergeant:
  • 219 Answers
Looking in the net I found someone running an E8500 on this board so I guess an E8400 will work fine.
Posted on Oct 30, 2009
Anonymous
SOURCE:
Ms 7399
The problem could be with the mother board.It is difficult to pin point the problem without checking Power supply, RAM and motherboard. Before going to any conclusion first disconnect everything from the Motherboard. i.e front usb connectors, front audio connectors, hard disk, cd/dvd drive and floppy drive (if there is one), cmos battery, keyboard and mouse. Now start the system. If there is no difference check with another power supply. Also clean the cpu fan if it is choked with dust.
When looking for a motherboard it may be difficult to get the same type. U may buy a board which supports core 2 duo processor and DDR II RAM. Your machine may be having DDR II RAM. Also boards are available which supports core 2 duo and DDR III Ram. That's all.
Mar 30, 2014 | Computers & Internet
I have a acer aspire m1640, with the motherboard fails, if i can not fix it, what motherboard, acer apart, can i mount it? thank you
There are a few options you have on this, but if you want to maintain full compatibility with your current hardware, then you must purchase a motherboard that supports DDR2 533/667 MHz SDRAM since that is what comes standard in Acer Aspire M1640 Desktops.
A few options that would be similar to stock motherboard would be:
Foxconn G31MXP-K I7 or Biostar TForce TG31-A7
Those motherboards have similar specs to the stock motherboard and you can take a look at the specs of the Acer Aspire M1640 from this link below:
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireM1640/AspireM1640sp2.shtml
Both those motherboards I have linked you too are microATX boards, which should fit fine in your case which may be a standard ATX case.
If you are willing to upgrade your ram, then your options open up to any motherboard that supports the Intel Pentium Dual Core processor. Since the stock motherboard also provides onboard video, chances are you don't have a video card plugged into your motherboard (unless you've upgraded that yourself) which means you should also look for a motherboard that provides onboard video so you don't have to purchase a video card.
Feb 26, 2011 | Acer Aspire M1640 Refurbished Intel...
I need a motherboard for this model. Gateway dx4720-03
The Gateway DX4720-03 Desktop PC, uses an MSI ms-7399 motherboard, made specifically by MSI for Gateway.
I just did a quick search and saw this mobo available for $75 US on Ebay. (Gateway DX4720, ms-7399)
This is not an advertisement for Ebay, nor the seller.
Feb 03, 2010 | Gateway DX4720-03 PC Desktop
I have a gateway MSII have a gateway MSI Ms-7399 mother board. I have an E6300 pentium dual core processor at 2.8 with a FSB at 1066,in it and it works fine. I want to know what the specs on the board are...
The board is maxed out at 1066 and it does not appear that gateway has a BIOS update to allow for the higher FSB reuired with the faster Intel chips. If you installed one of these newer LGA 775 chips into your computer it may work but would be a lot slower than what it is rated due to the chips multiplier would be set for 1333. I could not see any BIOS updates from gateway for this board. Also these chips are designed to run with the faster memory and the 800mhz memory speed would also be a bottle neck for your system.
Oct 10, 2009 | Computers & Internet
Download softweres
I would try the web site driverguide.com and fill out a free registration search the data base for your driver download and install the reboot your computer
Jan 22, 2009 | MSI P4M890M-L Motherboard
Msi p4n sli board
The Only CPU's that board supports are:
  • Supports 90nm LGA775 processor package
  • Supports Intel Pentium Processor Extreme Edition
  • Supports Intel Pentium D Smithfield processors
  • Supports Intel Pentium 4 / Pentium 4 Extreme Edition processors
  • Intel Hyper-Threading Technology ready
  • So sadly no I am sorry. However it does Support a P4 with HT which is still a very nice CPU
    Jan 15, 2009 | MSI P4N Diamond nVIDIA nForce4 SLI LGA775...
    Does msi motherboard P4M900M3 support this cpu Intel Celeron D CPU 3.20GHZ 512 Socket 775
    MSI has two boards P4M900M3-F, P4M900M3-L.
    Both of this will support your CPU
    Nov 26, 2008 | MSI Computers & Internet
    Supported ram speed for MSI 945pl-neo f
    Your motherboard MSI 945pl-neo support Supports four unbuffered DIMM of 1.8 Volt DDRII SDRAM.( Supports up to 2GB memory size.
    • Supports dual channel DDR2 memory architecture.
    • Supports DDR2 533/400 memory interface.)
    and Supports Socket 775 for Intel® P4 5XX, 6XX, P4EE, Pentium D 8XX and Celeron D processors.• Intel® 945PL/ ICH7 Chipset
    for more nformation see details od your motherboard here:
    http://global.msi.com.tw/index.php?func=proddesc&prod_no=227&maincat_no=1
    Dec 17, 2007 | Intel Motherboard
    Computers & Internet Logo
    2,498 people viewed this question
    Ekse
    Marvin
    Marvin
