Radio works fine but there is no sounds(music) playing, I thought it was the fuse, the put a brand new fuse, thought it was the speakers, installed new speakers, and what you think the problem is? Wiring to the speakers is good, I doubled checked that? Is my factory radio gone bad?if so, How can I fix that?
SOURCE: Radio fuse keeps blowing
something loose in the wireing when driving .the wires are grounding out
SOURCE: new radio installed - now dash lights don't work
Most factory stereos are wired to the dash dimmer switch. Usually if the dash lights go out after an after market stereo installation, it is because the wire that originally went to the factory stereo is not used for after market stereos. Double check the fuses and ensure the wire that controlled the lights on the factory stereo is not grounding out on something.
SOURCE: Radio does not work with the 1998 honda accord
I HAD THE SAME PROBLEM ..... ONE OF THE SPEAKERS WAS MAKING SOME KIND OF SHORT CIRCUIT. ITS USUALLY THE BACK SPEAKERS BECAUSE THE WIRES ARE NOT WRAPPED!!
SOURCE: 2004 Honda Accord Radio or CD Player. When I
Didi you find the solution to your problem? I seem to be having the same issue with my 06 accord
SOURCE: 2004 Honda Accord Radio fuse blows
There was a recall for the 03-04 Accord radio. It had faulty circuitry that caused the screen to go dim. Check with Honda to see if they'll still honor the recall.
