SOURCE: Forgot Digital Combination of Sentry Safe Model #SO500
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
They should be able to help. I would try calling first, to avoid paying the $12 to retrieve the combo, but with the serial number of the safe, they SHOULD be able to help you over the tele.
SOURCE: brinks fire resistant safe model 5059 instruction manual
To bad you dismantled. Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
SOURCE: LOST COMBINATION - BRINKS SAFE 5054
You can mail a notorized letter, requesting a combination...include model and serial number...mail to Sisco, 2835 E, Ana Street, Compton, CA 90221.....or fax it to 310-638-3489. I had the same problem and found out thru a Brinks website.
BEFORE YOU START
follow these steps:
TURNING SEQUENCE
SOURCE: I lost the combination for my brinks home security
Hi, You can contact Honeywell at 1-800-223-8566 . They are providing support for Brinks safes.
