managemylife... Master
- Posted on Jan 21, 2014
Re: oven keeps blowing thermal fuse
- Disconnect the oven's power supply by turning off the breaker in your home's service panel.
- 2
Open the lower oven door. Remove the screw at the bottom of the trip panel on each side of the oven.
- 3
Pull the trim away from the oven approximately 2 inches, then slide the trim panel down to remove it from the oven.
- 4
Remove the screws from the bottom sides of the control panel.
- 5
Pull the control panel out from the bottom, then lift the panel to remove it from the front of the oven.
- 6
Detach the wire connectors from the control panel by depressing the tab on each connector and removing it from the control panel.
- 7
Depress the tabs on the thermal fuse wire connectors, then remove the thermal fuse.
- 8
Attach the wire connectors to the new thermal fuse to install it in the control panel.
- 9
Reassemble the oven by reversing the steps used to take it apart.
- 10
Restore power to the oven.
