20 Most Recent managemylife.com Questions & Answers
First thing I\'d do is inspect the hose. Remove it from the washer entirely (use a bucket to contain stray water) and visually inspect / wash out with a water spray nozzle like a garden or kitchen hose. From the sounds of it, however, I doubt the hose is the issue, but you\'ll want to rule that out first.
If the hose checks out, then either the pump or the belt is the issue. Pumps tend to get clogged over time--I\'m not familiar with yours, but yours may be able to be opened (if so, it\'ll have screws holding it together) and you can remove it and clean it out. If it\'s clogged and a sealed unit, you just get a new pump.
If the pump looks ok, the belt might be slipping, but if that were the case you\'d probably have more issues. Still, depending on the age of the unit, you may want to replace the belt now since you\'re going to have to remount the belt after playing with the pump.
I use repair clinic for my guides while doing work, and if I can\'t find the part locally I use them to supply the parts. Check out this page for more help: Whirlpool Washer Won Drain . Of course, if the idea of taking apart your washer totally freaks you out, go hire a repair person. :) But they\'re not all that hard, honestly--more of just a pain to take care of, since this\'ll probably be your first washer tear-down. Best of luck, and watch those videos at repair clinic--they\'re pretty helpful!
managemylife.com | Answered on Oct 07, 2017
Try ordertree.com , amazon or sears.
managemylife.com | Answered on Jul 21, 2016
My question is my Kenmore Refrigerator display "Er 1F", What is means? How can reset it to normal?
My E Mail address is ([email protected])
managemylife.com | Answered on Jun 06, 2015
Try unplugging it for 5 min.
managemylife.com | Answered on Jun 22, 2014
Refer your inquiry to Sears.
managemylife.com | Answered on Jun 20, 2014
we also need more information to try to pintpoint the problem
managemylife.com | Answered on Jun 19, 2014
Most refrigerators have the opposite problem with little kids pulling the door open then walking away leaving the door open. You can resolve this issue by raising the refrigerator up slightly. .it's helpful to have 2 people for this task. On the front of the fridge on each corner or there of. There are a adjustable leg and by adjusting the leg in you will change the level of the fridge. The farther they are turned out the fridge will lean back and that will with the force of simple gravity make the door close on its own without any help the further in the legs are turned the fridge will lean towards the front. But with some help you can make the cabinet of the unit perfectly level then when you open the door it will stay right where you leave it
OK this may sound to simple. First check make sure that the softener has a good steady power supply. Check make sure it's plugged in. Then check the electric supply box...the fuse box and see if you may have tripped a breaker or a fuse. The softener should have a red or green light if you have power. Red light display means that the softener is in error protect mode a lot of times your timer needs to be reset like extended period of loss of power. ..but usually provided you have power without any outstanding issues. ..just unplug unit for 5 minutes the repower it up by simply plugging it back in
You probably bent a blade into the deck. Its possible that something else is wedged in between the blade and deck. You can set the front wheels on a block and look under the deck. With mower off and blade disengaged, see if blades turn freely. Check each blade seprately.
managemylife.com | Answered on Jun 14, 2014
Edgewise Media
630 9th Ave # 800
New York, NY 10036
Any issues with the water "uptake" to make the ice? Is it making ice & they just won't come out? Is the dispenser clogged? If you can provide a little more detail...better able to troubleshoot....is it making whirring noises (which would indicate the electrical is fine, but there's a jam or something).
managemylife.com | Answered on Jun 12, 2014
Does it show a faulty code. Where the sound coming from.
How long did you have the unit. Do you have a problem with water or ice. Have you ever cleaned condensor?
managemylife.com | Answered on May 29, 2014
That model was still made by A.Y.P. which is American yard products. A subsidiary of white outdoors the reason I am sharing this with you is that only ayp parts will interchange with your mow
managemylife.com | Answered on May 25, 2014
I've posted on this subject before. Your washer will not cycle correctly if there are any restrictions in the pump and this usually means that during doing the wash things have been transferred from your clothes generally the pockets. ..These things usually get lodged in the pump. When the washer enters the spin cycle the pump kicks in and pumps out the excess water. If you can get the back off the washer you will see a semi - round object that is usually white with 2 hoses coming out of it. One hose is the water in let hose the other one is attached to the drain hose that goes into the sewer drain outside of the washer. Make sure that the washer is unplugged then remove the hose that goes to the outside drain. Now with a flashlight look inside of the pump and see if you can see any debris or foreign objects. If you see anything in there you will have to remove these things through the hole where the hose connects. After removing debris replace hose inspect the surrounding area for obvious reasons why the washer may have stopped like look to make sure that the belt on the drive motor is ok. With no other signs of problems replace the back of the washer andplug it back in and try to sstart the washer just like you were just starting a new load of laundry. G
Go to your local hobby store ie:Michaels,Hobby Lobby, sometimes they have business card boards of people that can help you.
Should be a control dial up inside near the light.
managemylife.com | Answered on May 23, 2014
managemylife.com Logo
544 questions posted
Popular Products
Top managemylife.com Computers & Internet Experts
Kurt Bresler
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • managemylife.com Computers & Internet
Most Popular Question
hang rug wall
  • Computers & Internet
