20 Most Recent KitchenAid KEBC208 Electric Double Oven Questions & Answers
Oven keypad is completely black but inside oven lights work. does keypad have a separate fuse?
Yes. Many of these have a display thermal fuse that is part of the wiring harness that connects to the board... it should have continuity. WP4451042. Almost all models have what is called the "oven shut-down thermal fuse" which is on the back of the machine ( you have to pull it out of the wall and remove the back panel) and looks like this KitchenAid Range Stove Oven Thermal Fuse WP9759242
8/30/2016 7:24:25 PM • KitchenAid... • Answered on Aug 30, 2016
I spilled milk in vents of the top oven in my KitchenAid KEBC208 convection oven. This is the Superba line....
KEBC208 Parts List It's a parts store, but it also has all of the diagrams.
4/3/2016 5:23:07 PM • KitchenAid... • Answered on Apr 03, 2016
2answers
Kitchenaid oven door will not stay closed
I had the same problem on my parents Kitchenaid KEMS378GWH0 oven, the door would only close enough to keep the light on. They propped a chair against it to cook. My father replaced the hinges and it worked for about a week. He noticed that pulling outward on the door at the very bottom edge often allowed it to close enough to use.
After completely dismantling the oven to get access to the brackets that the hinges slide into, we found it was not broken. We decided to expand on the only near solution we had and find a way to make the bottom of the door 'push out'. Our solution was very simple. Remove the small metal plate that covers the door insulation. This revealed that the insulation is a braided hollow rope that is held in by small clips that push through holes in the front of the oven. We threaded some small metal rods about 3/8 inch in diameter into the hollow insulation pushed the clips back in to re-attach the insulation, replaced the metal cover plate.
It worked!
1/29/2016 3:06:31 AM • KitchenAid... • Answered on Jan 29, 2016
3answers
After using self cleaning feature...oven door
Hello - we have had this same issue a number of times as well. Do you lose all power on the unit too? We do - have discovered that using the self-cleaning isn't really a good idea with these ovens. The ovens aren't really made to heat to such high heats that are used in the cleaning cycle and during that last hour of cleaning it hits it highest peak - and it blows it's fuses. We recently blew 2 fuses at the same time, locking both doors (Double oven) and knocking out the power for the entire unit. Our repair man said that the average on wall ovens is anywhere between 6 - 12 cleanings before you will blow the same fuses and the whole cycle starts all over again. Our expense was $350. So, self-cleaning now means elbow grease around this house. How this information was a bit helpful for you.
4/25/2015 1:59:03 PM • KitchenAid... • Answered on Apr 25, 2015
Where would i find the probe
in the oven it will protruding out the top or the bottom
10/17/2014 5:03:47 AM • KitchenAid... • Answered on Oct 17, 2014
2answers
KEBS208DSS6 doors wont close compleat
Place a hammer handle between the door and the frame at the hinge location.
Carefully apply pressure on the door to push the door closed.
This will often re-set range door hinges.
7/10/2014 4:59:19 AM • KitchenAid... • Answered on Jul 10, 2014
0answers
0answers
manual
2answers
My oven has the blue enamel inside and I want to
Sorry to read about your problem, I hope this helps you out.
use regular oven cleaner, if you wish
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
7/19/2012 11:28:57 PM • KitchenAid... • Answered on Jul 19, 2012
Kitchenaid superba failure codes e1,f2, and door is locked
Hi Bill:The E1F2 error code indicates replacing the board. It is in the realm of possibilities that your new board is defective. If I were certain the board was good I would focus my efforts on tracking down an electrical fault.The likely failure is the control panel; however it could be the control board. Since you did replace the control board already, the problem is most likley a key pad that is sticking.I added a portion of the technical data sheet in the image below. You will need an ohm meter to be able to check the key pad operation. I added the information needed in the image below. If the control panel tests OK, replace the control board, if it fails, replace the control panel.You may need a hands on tech to run these tests and diagnose and repair your oven. Or just buy the key pad controls. Check THIS LINK.Here are the parts Replacement parts for WHIRLPOOL KEBS208DSS8 ' AppliancePartsPros.com Here is a manual and a tech sheet https://secured.whirlpool.com/Servic...all%20Oven.pdf http://www.servicematters.com/docs/w...%204451879.pdfHope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer. Thank you for using FixYa, have a nice day.
12/20/2011 7:47:28 PM • KitchenAid... • Answered on Dec 20, 2011
Have had my double oven
Your missing several digits on the model number. You must find the number on the oven itself and not the manual.
3/23/2011 10:29:22 PM • KitchenAid... • Answered on Mar 23, 2011
Oven door doesn't close all the way
You can adjust the door with the philipes head srews on the hing.
2/22/2011 5:36:27 PM • KitchenAid... • Answered on Feb 22, 2011
We lost power to the
there is a thermal fuse in the back or on top of the oven that is blown. its designed to blow if the oven gets too hot. you will have to remove the oven from the wall to check it. thats probably why kitchen aid wants to send someone out.
2/4/2011 12:08:00 AM • KitchenAid... • Answered on Feb 04, 2011
My oven display has a
This problem is caused by defective material in the core
of the solenoid on the door latch. The solenoid works
properly at normal temperatures, and at the beginning of
a self-clean cycle. However, when heated, the plastic
core binds the metal plunger, and will not allow it to unlock
at the end of a cycle. Once cooled, the solenoid will
again work properly. When a technician inspects the
solenoid while it is cool, it will function normally.
SOLUTION: Replace the solenoid with service solenoid #4452224.
Oven repair in Mission Viejo, CA
Appliance repair in Mission Viejo and Orange County, CA
1/27/2011 2:01:24 AM • KitchenAid... • Answered on Jan 27, 2011
KitchenAid KEBC208 Electric Double Oven Logo
46 questions posted
Top KitchenAid Ovens Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Ovens
  • KitchenAid Ovens
Most Popular Question
need replace glass door one our
  • Ovens
