791 transponder will not work. remote will start if key is in the ignition only
SOURCE: Remote won't work and parking lights blink
the blue wire needs to go to -input then unit should work
SOURCE: Have a Ford transponder2 in a Nissan Xterra when I
So, this is a transponder key box, correct? And, the vehicle starts with the remote starter when you put the key in the ignition but, the vehicle will not start when you put the key in the key box, correct? If what I have explained above is the issue, there could be one of several problems. The key box may not be getting power and/or ground when running. Test to make sure. Next, the antenna ring going to the ignition cylinder may need to be adjusted to insure that the signal is being received by the vehicle. Next, if the vehicle starts with key in the ignition; also test that the remote starter works with the placed by the ignition cylinder (without being placed in the ignition). If the remote starter starts with the key IN the ignition but not with the key being placed BY the ignition cylinder, you may need to activate the key sense wire during remote start.
SOURCE: remote start only starts with key in the ignition
It sounds like the immobilizer bypass module has either lost its programming due to the dead battery or a voltage spike from jump starting/recharging the battery or it has malfunctioned. Without knowing which module is installed, it is not possible to determine if it can be reprogrammed. The immobilizer bypass module substitutes the transponder that is in your key and allows the vehicle to start. When it is malfunctioning, it may not be providing a signal or providing the wrong signal the vehicle ECU is expecting. The reason you can remote start the car with the key in the ignition is because the transponder is being read fromthe key and the ECU is allowing the vehicle to start.
SOURCE: Transponder for 2006 mitsubishi eclipse for remote starter
Yes, There are two Immobilizer bypass modules on the market that will work with your vehicle without having to sacrifice a key. Xpresskit offers the DBALL and PK9. Both require programming to function properly.
Testimonial: "Thank you"
blue wire is hooked up, key will not work outside of the cylinder. how do I activate the key sense wire
You will need a bypass module for you car. This will "fool" the car into thinking the key is in the ignition.
