SOURCE: how do i clean the top of my gemini stove
Use Baking Soda and water and form a paste. Use this to clean the top of your stove. If food is really baked on, you might also consider using a single blade razor to scrape the mess off. Rinse well.
SOURCE: Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
SOURCE: Maytag MGR6775 Gas stove. One igniter not working.
Clean the burner with a wire brush around where the ignitor is. it needs a proper ground to ignite. When you turn the burner on do you hear a click click click? If so this should solve the problem.
SOURCE: admiral wont heat
You have a incoming power problem. Verify 220 volts at the wire terminal in the rear of the range. No 220 there,check your house wiring and breakers.
