Maytag gemini gas oven tough controls won't work -- oven shut down while on and nothing works on touch panel other than clock still on.stove top burners still work. unit is about 7 years old
It's most likely the control board. It depends on age of unit and cost and time of repair. It may be quicker to just get new unit with holidays just around corner.
IF IT IS STILL UNDER WARRENTY DON"T TOUCH IT CALL THEM BACK , MAYTAG HAS MANY PROBLEMS BUT THEY ARE GOOD AT REPLACING UNITSTHATHAVE PROBLEMS , PLEASE LET ME KNOE WHAT HAPPENS IF YOU NEED ME TO CALL THEM GIVE ME THE INFO AND I WILL DO THIS BUT SHOULD BE OK
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
the elect clock controls the oven and is probley the problem . . some have thermostate's ( saftey ) but in most cases they shut down the complete oven .. mm
This simple test will help determine whether the ERC (Electronic Range/oven Control or Clock) or the touch pad is defective when this error code is present.
1. Disconnect power to the range/oven (unplug the range/oven power cord or turn the power off to the range/oven at the circuit breaker). It is very important that the power to the range/oven has been disconnected, so please double check before continuing. 2. Gain access inside the control panel. 3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC/EOC. 4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was. 5. Turn the power back on. 6. Wait for at least one hour to see if the code comes back (usually accompanied by a beeping sound). 7. If the code comes back and the beeping as well, replace the ERC(control board). If it does not, replace the touch pad.
if it's just the stove, it's not the control board because the rest of your stove work. if it's just the oven, it most likely the thermostat, blower or the heat probe. go to www.reliableparts.com to get parts for it.
Thanks -- we'll check it out
