THE T9510-04 SUBS ARE SINGLE COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-04.pdf
THE T9510-44 SUBS ARE DUAL VOICE-COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-44.pdf
SINCE YOU NEED A 1 OHM LOAD, I PRESUME BRIDGED AND ARE USING TWO SUBS, THEN HOPEFULLY YOU HAVE THE DUAL VOICE COIL TYPE, AS THEY ARE DUAL 4 OHM AND YOU WILL HAVE TO CONNECT THE VOICE-COILS IN PARALLEL WHICH WILL MAKE EACH SPEAKER A 2 OHM SPEAKER AND THEN CONNECT THE TWO SPEAKERS
THEMSELVES IN PARALLEL AND THIS WILL PROVIDE YOU THE 1 OHM LOAD. IF YOU IN FACT HAVE THE SINGLE 4 OHM
VOICE COIL VERSION, THEN IT WILL ONLY PARALLEL THE PAIR DOWN TO 2 OHMS. OK. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
