My entire touch is not workingOnly a portion of my touch screen works..especially when trying to send texts, certain letters and symbols would not register or display
My entire touch is not workingOnly a portion of my touch screen works..especially when trying to send the text
My Samsung cell phone limits me to 140 characters so this is not unheard of. I split my messages to under 140 and ask people who need to write a veritable epistle to do so by email because my phone cuts vital pieces when it chops messages up on receipt.
Even though the iPhone is a device that is extremely convenient to have, it still can cause frustrations. Specifically, there may be times when the touch screen does not work properly.
There are various problems the iPhone touch screen could encounter. Although there are times when the screen does not work altogether, there are other situations when certain portions of the screen work and others don't. Of course, it is possible that the entire screen works, but is simply slow. Regardless of the exact problem, there are ways to troubleshoot the iPhone to diagnose the real problem.
dear sir, in your phone there will be a small key named c ahich has a symbol similar to the back space key in computer keyboard........... jst press that key and that is the key to delete not only letters,it also deletes files from your mobile... thank you...take care
Finally, replace the firmware and system software using webupdate. Replacing the system software will most likely correct the malfunctioning keying of letters.
Go to messages, new message, go to the menu(middle button) select entry options/method/settings, go to primary and select TAP English, go to Secondary and select None. Text-Entry Methods: iTAP - Lets you enter words using one key press per letter. The iTAP® method combines your key presses into common words and predicts each word as you enter it. TAP - Lets you enter letters and numbers by pressing a key repeatedly to cycle through the letters and number on that particular key. TAP Extended - Same as TAP, but cycles through additional special characters and symbols as you repeatedly press a key. Text-Entry Modes: Primary - You can set your Primary entry mode to any iTAP or TAP entry method. Secondary – You can set your Secondary entry mode to any iTAP or Tap entry method, or you can set it to None if you do not want a Secondary entry mode. Numeric - Enter numbers by pressing the number keys. Symbol - Enter symbols by pressing a key; its symbols are displayed at the bottom of the screen. Scroll to the desired symbol and then press Select. To set the text-entry mode or method:
From a text-entry screen, press Options.
Scroll to and select Entry Setup or Text Setup.
Select the desired text-entry mode or method.
Tip: From any text entry-screen, you can quickly change your text-entry mode without leaving that screen. Press the # key repeatedly to cycle through the text-entry modes: Primary, Secondary, Numeric, and Symbol. With each press of the # key, the mode indicator in the upper left of the text-entry screen changes.
Look for the CC/Text button on the remote. The TV is in the TEXT mode and is showing garbage that is being sent by the broadcaster, You need to turn the CC/TEXT mode off.
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to
allow you to enter text, numbers, and symbols just as if you were using
a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY
(typewriter) keyboard on the touch screen to allow you to enter text,
numbers, and symbols similar to the way you would using a QWERTY
keyboard. To use Touch Keypad or Touch Keyboard: In a program, tap
the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard.
To type lowercase letters, tap the keys on the dial pad or keyboard. To
type a single uppercase letter, tap the Shift key and then tap the
corresponding key. To type all uppercase letters, tap the Shift key
twice. To change back to all lowercase letters, tap again. To enter a
space after the word, tap the Space key. To start a new line, tap the
Enter key. To backspace and delete a single character in any input
mode, press the Back key. To open the Symbol pad, tap the Symbol key.
To change the input mode: Tap the Input mode key to switch to a
different input mode: XT9 (predictive), Multitap (abc), or Numeric
(123).
Hope this helps, let me know if this works or if I can help you with anything else. JimmyC
Have you tried using the screen calibration command? Press the Wrench symbol, then the Display symbol and then Calibrate screen. Press the dots as it tells you to and you should now have a calibrated touchscreen.
dck2's solution worked for me on my razr, I opened the text message, went to "copy all text", went to "Create Message", chose "New Multimedia Message," went to "Paste," and then sent it to my email address, and the entire message went to email, including the date.
