Question about UTStarcom Blitz Cell Phone
My blitz doesnt text
I was texting on my phone i put it down to go make something to eat. i came back and when i tried to text again the keypad wouldn't work. any of it! even the number part. it just stopped working. i mean i spilled sprite on it like last year but that hasn't affected the phone at all. what is wrong?
Posted by urokurulipow on
Anonymous
  • 403 Answers
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Hope this helps, let me know if this works or if I can help you with anything else.
JimmyC
Posted on Oct 06, 2009
My blackberry curve starting texting weird, i pressed 1 letter in a text and that letter plus 5 other letters would appear, til i got to the point i couldnt text at all. now its just went to screensaver...
Hi
seems like you have a problem with the keypad. may be a water damage or moisture damge keypad near the track pad. thats make your keypad malfunctioning and it just keep sensing like you keep pressing a key while even if you are not using your phone. you can try remove your battery and put in a bowl of rice for 1 day or you can try drying your phone with air dryer. if its still the same issue then you may have to clean your keypad contact. thanks.
Oct 16, 2011 | RIM BlackBerry Curve 8520 Smartphone
How do i turn off t9?
this phone doesnt carry t9. one way to use the predictive text dictionary (ptd) on this phone, is to hit that "0" sign with the circle shaped arrow on the keyboard after typing in a series of letters..
Feb 11, 2010 | UTStarcom Blitz Cell Phone
My Blitz won't turn on some reason. I was texting then it turned off, I tried plugging it into the charger and it would change battery life all the time. I've tried taking the battery out for a while then...
look closely at the battery. you know those rectangles that are on the top of the battery that connect to the phone? if they have any little marks on them that means that the battery is damaged. it can become damaged from over charging. so only option is to get a new battery. Oh and your problem is that the battery died.just get a new one. hope this helped:)
Dec 09, 2009 | UTStarcom Blitz Cell Phone
Keypad makes phone freeze
its ur mobile application problem. so u need reinstall ur mobile application.
Aug 03, 2009 | Motorola Mobility L6 Cellular Phone
Keyboard keeps defaulting to numbers when texting
configure received message settings:
1. From standby mode, press the OK Key [OK] to unlock the keypad,
then press the Left Soft Key [Message], then the Left Soft Key
again for [Settings].
2. Press the Directional Key up or down to highlight one of the
settings below, then press the OK Key [OK] to select it:
ENTRY MODE
Sets an Entry Mode as a default. For example, if Abc Mode is the default, its icon
will appear.
1. Select "Abc", "ABC" or "123" by pressing the Directional Key up or
down then press the OK Key [OK].
Jul 18, 2009 | UTStarcom Blitz Cell Phone
Screen doesn't turn sideways into full keyboard in text mode
Mine has done this twice. Only for TXT messaging which is what I use the full keyboard for. The first time I think I had too many apps on that were eating up my memory, so I deleted one that took up a lot of room and it started working again and was fine. Then it did this again yesterday. I did a hard restart (after having restarted it from the keypad, which didn't seem to work) I pulled the battery - which I hate doing. It started working as soon as it rebooted. Gotta love technology :)
Apr 08, 2009 | RIM BlackBerry Storm 9530 Smartphone
Text Messages
easy go on messages, go down to settings, click on text messages, then on profile settings, then click first one and in put you service centre number
Jan 26, 2008 | Samsung SGH-E900 Cellular Phone
UTStarcom Blitz Cell Phone Logo
Top UTStarcom Cell Phones Experts
ADMIN Canada
ADMIN Canada
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
