Stopped recharging,not lighting up,after not being charged for 2 months,may be bulb is blown off,but on looking at bulb from near after opening front glass cover-looks to be OK.
Check and replace the bulb. Make sure your charger has power coming out of it. Also, depending on how long you have owned this the battery could be shot. Just as cheap to buy a new light as it is to buy a new battery.
Your regulator may have went bad. The regulator converts the ac charge produced from the alternator into the DC volts required to charge the battery. When they fail they can put out 5 times what the battery needs. Depending on your bike the regulator may be separate from the alternator. You should pick up a cheap volt meter. Once you get the bike running, use the volt meter to see what the bike is charging at. If you find the charge is above 14.8 V or that the voltage fluctuates to the extreme, ex. 14.2v, 8.2v, 12.7v all within a few seconds. then the regulator is probable. Another problem I have found is that the ground wire for wiring harness does not get hooked back up. This is a smaller ground wire that may plug into the main ground cable or sometimes is a separate lead connected to the battery. This will fry an entire system.
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
If they all stopped working at the same time then it is probably a fuse or possibly 2. Check your fuse panels in the dash and under the hood. The dash lights and gauges should be a fuse labeled instrument cluster or guages, it is probably blown. The other fuse to look for will be the tail light fuse. This is where I would begin.
