I want to hook up one sub to a PPI amp but has four terminals what two terminals do I use
I'm not familiar with this amplifier but in most cases, if a mono amp has more than one positive speaker terminal and more than one negative speaker terminal, the positives are directly connected and the negatives are directly connected. So as long as you connect the speaker positive to a positive speaker terminal of the amp and the speaker negative to a negative speaker terminal of the amp, it will work properly.
You're trying to "Bridge" the stereo signal into a mono signal for a single sub right. Try both positive input sockets from the L & R channels for a 2chn amp, if it's a 4chn amp use the 2+ input sockets of the front side of the amp. Most amps work this way specially the old old ones manufactured late 80's. Just make sure the pos+ wire from the sub is hooked up to a pos+ terminal too.
Ppi d3000/1 it burned out 2 1/2" circirt on the power cable side next to 4 push button, on the circurt board its on d310 and next to it it looks the same. if i could get a number for the part it would be great help.
