The PCX-1500 is a single channel amp, it can't be bridged. I realize that it has two sets of speaker outputs but electrically it only has one output. The connections are actually paralleled inside. Electrically it only has one output. Physically there are just two sets of terminals to allow more convenient connection of 2 speakers. You can use either one or both. If you use both you need to take into account that they're parallel to each other. Connect 4 ohms to each set the amp sees 2 ohms. Like wise with 2 ohms to each set, the amp sees 1 ohm.
Hope this helps.
SOURCE: I have a PPI PCX-2400
That would depend on the impedance (resistance) of the subs. Your best bet would be to use the full power of the amp to one channel (i.e. bridged) instead of to two separate channels (i.e. stereo). Two 4 ohm subs wired in parallel would present a 2 ohm load to the amp, which should allow you to get all 1600w out of it.
This explains series vs parallel quite well:
http://www.termpro.com/articles/spkrz.html
If the woofer isn't moving significantly, try the following settings:
gain at highest (most sensitive) setting
crossover at highest frequency
subsonic filter at the lowest frequency
If those do nothing and you have a dual voice coil woofer, you may have one coil reversed. If you disconnect one voice coil and the woofer moves significantly more, check the polarity of all speaker wire connections.
Here's a brochure for the amp:
http://cartoys.com/cartoy/pdfs/eclipse_amp_manual.pdf
You're correct. this amp cannot be bridged to produce more power. It's minimum safe load is 4 ohms per channel. It's essentially two bridged amps in one chassis.
