SOURCE: I have a GE profile spacemaker microwae oven. The
Yes. You can find
links to helpful exploded view diagrams and part ordering help
here.
I'd recommend that your bookmark this link to your favorites.
There should also be a "mini-manual" hidden inside the unit behind the control
panel or hidden on the left side behind the grille, which is very
helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If yours is a counter top model, you have to remove the outer cover, and the mini-manual will probably be in an envelope inside the wrapper.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: fridigaire microwave does not turn on
Your aren't giving me much to work with but I have fixed a bizillion microwaves and in most cases they blow the fuse (probably 18 amps) and it is because the HV diode shorted. So both would need to be replaced. Not a big expense. I would think about $50 from a reputable company. There are some exceptions of course. If the unit is very old it could have a bad magnetron in which case it is not worth repairing. The unit may only need a fuse. Everytime you hit go the microwave makes a very hard demand on power and over time the fuses can blow. Let's hope for the best a new fuse. Let me know how this works out.
hardrocko
