also che the starter and the wiring .and make sure you can turn the by hand first.also che the starter and the wiring .and make sure you can turn the by hand first.
Check spark at the spark plug by putting a screw driver up the cover hold it close to an earth and get some one to crank it over ,the spark should jump to earth.
i have an 03 yukon and i just replaced the fuel pump and it ran for 2 hours then it just died on the highway. it turns over but will not start. whats wrong with it???
yep,that sounds like the fuel pump is getting hung up on the bearings.don't forget to put a new fuel filter on too!
you'll see the blackness of the fuel that got stuck in the filter.
Then it is the fuel pump. Can you hear the fuel pump come on if not that is what it is. That is why when you put fuel in the intake it started. Good Luck.
It's never a good thing to let Fuel Injection run out of Gas. The Fuel pump runs on Low Voltage and has a Hard time Restarting. Could also have had some (Gunk) at the bottom of the Tank that got into the Fuel System. Keep tryin to start Her for a while and see if the Pump won;t pick up. Also got a Long way for the Fuel to go to the Motor in that Suburban! Let me Know!
