Cars & Trucks Logo
James Keebler Posted on Nov 25, 2013
Rear harness was bad they replaced with trailer harness and trying to fig out what yellow brown light green an dark green are on frame of truck it hooked in to so i can fix i un hooked not knowing what had been done i have running lights brake lights but front turn bulbs come on when i hit brakes and flashes both rear turnd one way nothing other on harness white is ground on trailer replacement green is or was connected to yellow brown ? so lights have white ground a brown on each and dark green but hook them up way i remember and nothing do i re connect both greens to yellow like they were? and what about browns cause dark green on fram i don't know were it went? it's a mess helop
John Mitchell
Level 1:
  • Contributor 24 Answers
  • Posted on Nov 25, 2013
John Mitchell
Contributor
Level 1:
Answers
24
Questions
Helped
9670
Points
61
Your description, I take it, is a problem with the wiring harness going from the driver's compartment to the rear lights. If that is the case, the normal color code for GM is brown for tail lights, dark green for the right stop & turn, yellow for the left stop & turn and light green for the backup lights. Any black wires should be grounded. The white wire in the trailer harness is for a ground when used on a trailer. It sounds like you have the green and yellow T&S wires shorted together somewhere! Some of the later vehicles use separate stop and turn bulbs... these would have a separate wire for the stop lights only, but I don't think your truck is new enough for that. Good luck!
Testimonial: "Thank you very much I am disabiled and can not afford to take any were. i added anoter ground from alt to clean sorce and it started working great. now God bless you helped a man feeling useless fix his truck lights right. now i half to find a presser fitting to fix break line they replaced line all way to front 1 ft from broken line coming down from master cylinder i am going to un do some cicles and get length and use pipe cutter to get smoth clean cuts and hope to find right pressure unions to fit. and can do it my self. i got to eat and this truck is eating away at food money."
  • John Mitchell Nov 26, 2013
    Glad I could help you! You should use flare fittings on your truck for brake linings because of the high pressure. Compression fittings will work, but are not recognized as a safe, reliable repair.
5 Related Answers
Anonymous
  • Posted on Mar 04, 2009
SOURCE: No left brake light on trailer when hooked up to truck.
I had the same problem but when i tested the left turn signal then tested the brakes both brake lights would then work.
Anonymous
  • Posted on May 23, 2009
SOURCE: Both rear turn signal lights flash
Bad Ground!
Anonymous
  • 37 Answers
  • Posted on May 26, 2009
I did 15a and electrical for over 30 for chevrolet and seen some pretty weird stuff.To me you still have a ground problem.your idea of checking the brake light switch is a good start.both rear lamps flashing to me means the hazards are shorting across the turn and brake light circuits,because hazards stop flashing when brakes are applied.The brakes light switches in the 90's were really weird because they also incorporated the abs system.Good luck,let me know what happens.Thanks
Anonymous
  • 61 Answers
  • Posted on Jul 24, 2009
SOURCE: all lights work and brake light at top works.
Check a few things...
- The bulbs
- Check for ground at brake lamp connectors
- Check your wiring at the connectors for power
- Check for another fuse blown
- Do not hook up the trailer until you fix the ground problem on the trailer
- On some models, there is a module to control the rear/trailer lighting system. There may be a problem in the module.
Anonymous
  • 12 Answers
  • Posted on Aug 05, 2010
SOURCE: 99 gmc jimmy. no brake
Should be switch clear at top of brake peddle if I remember right it looks like a tube facing fire wall
1993 chevy c1500 stock radio wire harness colorsfor all 3 oem radio plugs
Here are the wire colors and their corresponding functions for the three OEM radio plugs in a 1993 Chevy C1500:
Plug A:
  • Yellow: Battery
  • Red: Ignition
  • Black: Ground
  • Gray: Illumination
  • Brown: Dimmer
  • Light Green: Left Front Speaker (+)
  • Tan: Left Front Speaker (-)
  • Dark Green: Right Front Speaker (+)
  • Light Blue: Right Front Speaker (-)
Plug B:
  • Orange: Constant 12V+
  • Yellow: Switched 12V+
  • Black: Ground
  • Brown: Dimmer
  • Light Green: Left Rear Speaker (+)
  • Dark Green: Left Rear Speaker (-)
  • Brown/White: Right Rear Speaker (+)
  • Yellow/Black: Right Rear Speaker (-)
Plug C:
  • White: Left Rear Speaker (+)
  • Gray: Left Rear Speaker (-)
  • Purple: Right Rear Speaker (+)
  • Green: Right Rear Speaker (-)
Note that the wire colors may vary slightly depending on the specific year and model of the vehicle, as well as any modifications that may have been made to the wiring harness. Also, keep in mind that it's important to properly match the wires from the harness to those on the radio to ensure proper functionality and avoid damaging the radio or other components in the vehicle.
Whats the color codes for a 2001 dodge ram 1500 stereo wiring harness?
2001 Dodge Ram 1500 Radio Wire Colors
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Dark Green
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
1helpful
2answers
I need a trailer wiring diagram for a 2000 dodge dakota sport
Dark green with red wires the left stop turn signal Dark green with brown is the right stop turn signal Black with yellow is the tail lights.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Installing aftermarket stereo in 99 silverado which wires from stock harness connest to aftermarket harness
connect the wires as indicated below
1999 Chevrolet Silverado C1500 Wiring, aftermarket stereo wire colors
Car Radio Battery Constant 12v+ Wire: Orange, yellow
Car Radio Accessory Switched 12v+ Wire: Yellow, red
Car Radio Ground Wire: Black, black
Car Radio Illumination Wire: Gray (Tape off) not used
Car Stereo Dimmer Wire: Brown (Tape off) not used
Left Front Speaker Positive Wire (+): Tan, white
Left Front Speaker Negative Wire (-): Gray, white/black
Right Front Speaker Positive Wire (+): Light Green, gray
Right Front Speaker Negative Wire (-): Dark Green, gray/black
Left Rear Speaker Positive Wire (+): Brown, green
Left Rear Speaker Negative Wire (-): Yellow, green/black
Right Rear Speaker Positive Wire (+): Dark Blue, purple
Right Rear Speaker Negative Wire (-): Light Blue, purple/black
It was wired for a 4 wire flat trailer plug. the plug was ripped off and now there are wires coming from both tail lights and the drive lights on rear passenger and trailer dont work. Green, Black, brown/w...
You need to install a 3-2 wire converter. I suggest a CURT 56175 then
1.Using a test lamp, identify the corresponding wires in the harness for the left turn, right turn, tail lights and brake lights. 3. Temporarily remove the vehicle's negative battery cable from the battery. 4. Using wire taps, attach the input wires of the tail light converter to the corresponding vehicle harness wires identified in step 2 as indicated.
Converter Brown Wire: Tail Light Circuit Converter Yellow Wire: Left Turn Circuit Converter Red Wire: Brake Light Circuit Converter Green Wire: Right Turn Circuit
5. Locate a suitable mounting location for the ground eyelet on the vehicle near the converter on vehicle's frame or cross member.
And your ready to tow!
1helpful
2answers
The wiring harness. To the stereo has been cut. I need to install oem stereo and don't know where to start to find which wire hold the ground or power.
1998 Chevrolet Malibu Car Stereo Wiring Diagram
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4? x 6?
Car Audio Front Speakers Location: Doors
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Hope this helps (remember to rate this).
My o3 navigators adjustable brakes will only move about 1/2 inch either direction. It's fine if they don't work but is there any way to move them to the farthest position manually?
With both tail light lenses removed locate the black with yellow wires and the dark green with brown wires coming out of the brake/tail/turn signal sockets.
The black with yellow wire will be the running lights or tail lights and the brown wire from the trailer harness will attach to it.
The green wire on the trailer harness will be the right turn signal and will be attached to the passenger side tail light harness dark green with brown wire.
The yellow wire on the trailer harness will be the left turn signal and will be attatched to the dark green with brown wire on the drivers side tail light harness.
The white wire on the trailer harness is the ground wire and will need to be attached to a good ground. Is it pretty easy to crimp an eyelet onto the end of the wire and use a self tapping screw to attach it to the body behind one of the tail light lenses.
Here is a trailer light/wiring article I have done in the past. It has a couple of good tips you may find useful.
http://www.hotspotoutdoors.com/forum/ubbthreads.php/topics/1425999/1/Trailer_Wiring_101
How to wire a 4 pin connector for a LED Tailgate bar into the brake lines on a 2000 dodge dakota without trailor plug
The yellow wire on the trailer harness will be the left turn signal and will be attached to the dark green with brown wire on the drivers side tail light harness.
4helpful
3answers
What color is positive speaker wire on 1998 blazer
1998 Chevrolet Blazer S-Series Stereo Wiring Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6 1/2" Rear Doors Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
2helpful
1999 chevy tahoe 5 wire trailer wires, what does each color do?
Yellow is the left turn signal, White is ground, Dark Green is the right turn signal, Brown is the running lights and brake light, the others are for the electric brake set up for the trailer.
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
