How do you mean it turns off?does the timer move to off or is it the motor is bad,overheating and shutting down?if it's the timer try it on auto or more or less and timed dry and see what it does,but if it just dies and then after a while you can start it again it sounds like you have a bad motor but this is just a guess without being there,this is an older dryer and not to expensive,i wouldn't put to much into this dryer.it wil cost you around 120 dollars for a new motor and blower wheel but if the blower wheel comes off the motor shaft you won't need it,if you're handy it's not a hard job but for another couple of hundred dollars you can get a new dryer,your call let me know what you find and what it's doing,also when you go to start it does it make a noise like a loud ahhh sound>if so it will be the motor.
SOURCE: Kitchenaid KGYS750LQ Drying very slowly
Fixed myself after talk with parts counter guy. One of the gas valve coils fails when they warm up. Repair kit comes with both.
1.) Unplug dryer. 2.) Remove dryer front panel. 3.) Remove the two screws on the coil hold down bracket. 4.) Slide one up and off. Then the other. Don't mix them up, one has two wires in slide connector, the other has three. 5.) Reinstall coil hold down bracket and front panel.
Fixed my problem. My cost was $17.00+tax. My part #279834.
SOURCE: KitchenAid Gas Dryer wont heat everything else
Does the dryer heat at all? turn you dryer on for about 1 minute then open the door, any heat? yes= check to be sure you venting is good and clear. if good then you have 2 common issues i would check first. the thermal fuse could be blown or the gas valve coils could be bad. give me you model number and i can give you more suggestions of what to check and how
SOURCE: Our Kitchenaid dryer won't heat up - it's still
Hello, Before you proceed you should understand any service you perform on your dryer could potentially void any warranty, It is your discretion. I wouldn't be too concerned about the unit cycling on & off at the end of a cycle, many dryer's have an automatic "wrinkle guard" feature and that is how they function and some cycle on & off for up to an hour after or until the door is opened. I also am not clear if it is gas or electric soooo...if it's electric, disconnect the vent from the dryer and run a "timed" dry cycle not "auto-dry" without a load and see how it perform's. If it performs ok then you have your problem...poor or blocked venting. On the other hand if it is gas, you should not run the unit without it exhausting outside and consiquently you'll have to wait for a authorized pro. The other thing you want to investigate is how well the washer is spinning the clothes, are they fairly well rinsed before entering the dryer ? Just something to consider, obviously soaking wet is not good for drying in the dryer. Let me know if any of this help's and I'll watch for your response. Good luck and thanks for coming to fixya today. Please rate the info provided positively if helpful and reply to me if not helpful. Thanks again, macmarkus :)
SOURCE: KitchenAid Electric Dryer KEYS700G turns on and
You probably have a broken belt or your belt has slipped off of the idler pulley.
I will send you what works on a Whirlpool,Roper, and numerous dryers, maybe it will work for you.
http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Testimonial: "Thank you so much! That's wonderful help. I appreciate it."
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
