20 Most Recent KitchenAid KGYS850LT Gas Dryer Questions & Answers
faulty door switch, electric power shortages, lint filter clogged, defective circuit boards,......
KitchenAid... | Answered on Feb 25, 2015
just throw this out there. does have good ground
KitchenAid... | Answered on Dec 29, 2012
Here is the part in case you need it.
Here is a video to show you how to access it.
KitchenAid... | Answered on Oct 23, 2012
Look at the parts diagram on this page. The igniter is number 4 on the diagram.
You will need to replace the cycling thermostat. Here is a link to the part you need.
Here is a video to show you how to replace the thermostat.
KitchenAid... | Answered on Oct 16, 2012
automatic
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
KitchenAid... | Answered on Jun 05, 2012
the blower wheel is reverse threaded which means you have to turn the opposite way to remove it. Its easier with two people but to be honest, most of the time I have to break the blower wheel because its fused to the motor shaft
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
KitchenAid... | Answered on Aug 15, 2011
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
KitchenAid... | Answered on Jul 14, 2011
Hello, Thank You for using FixYa. I will be helping you today.You remove the lint filter then remove the two screws under the lint filter then grab each back corner of the top and firmly pull forward and then up. Its easy if you do one side at a time.
Thank You and please rate my answer if it was helpful..
KitchenAid... | Answered on Jun 10, 2011
heatman101
KitchenAid... | Answered on Apr 26, 2011
http://www.repairclinic.com/Dryer-Troubleshooting
KitchenAid... | Answered on Mar 05, 2011
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
KitchenAid... | Answered on Feb 20, 2011
heatman101
KitchenAid... | Answered on Jan 15, 2011
KitchenAid KGYS850LT Gas Dryer Logo
Popular Tags
60 questions posted
Top KitchenAid Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Dryers
  • KitchenAid Dryers
Most Popular Question
remove fan blower off motor
  • Dryers
