Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel Logo
Posted on May 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water pressure very low
Ii have a kichen faucet Grohe Alira - after about 2 years the water flow started getting less and less and now there is almost no pressure. I cleaned out the filter at the end, but it did not help.
  • igor522 May 03, 2009
    I removed all the parts at the end of faucet and cleaned them. I don't thing there is a canister filter - both hot and cold water connect directly into faucet
  • Anonymous May 11, 2010
    Do you have a cannister type filter on this faucet under the sink?
    Did you remove all the parts in the end of the faucet and clean them or did you clean them without removing them?
Anonymous
Level 3:
President:
  • Master 1,489 Answers
  • Posted on May 03, 2009
Anonymous
Master
Level 3:
President:
Answers
1489
Questions
7
Helped
766360
Points
4966
Sounds like the cartridge needs to be cleaned or replaced. May be clogged or faulty. This requires turning off water under the sink and pretty much taking the faucet apart.
Why is my grohe alira kitchen faucet loose
There is a nut up under the counter its hard to see but tighten that . Most faucets come with a special tool fo hat but can be done with wrench
3helpful
2answers
Grohe ladylux cafe faucet has low flow eventhough supply valves are wide open. This is true for both hot and cold. When supply is disconected from faucet and valve turned on there is ample pressure. Is...
I have the same problem and have the fix. There is a water pressure regulator on the bottom of the faucet( under the sink) this part is bad. Grohe will replace it for free. Call Grohe at630=582=7722 tell them the model # of the faucet and the color of the regulator, they will send you a new one for FREE.
I have a Grohe Ladylux Plus and the water pressure was good till about 6 weeks ago. Now I have very low flow in kitchen. What do I do?
If it is just this faucet and no others then it is likely the filter screen in the tap head is clogged.
Remove the cover from under the tap head. Pries off from the tap head directly where the water comes out.
There is a metal mesh screen there. It will be full of white chalky deposits from minerals in the water supply. Clear that out and you will be good to go.
You will also want to clear the holes for the spray pattern. The same deposits will be there.
Good luck.
If this helped give you some direction please rate the answer for me.
Thanks.
Low hot water pressure on Grohe LadyLux.
1. If by replacing the flexible hose you mean the hose for the pull-out portion - you have more than likely kinked or bent the supply line to the hot (left) side of the faucet.
a) If this supply is braided, then simply shutting of the water supply, removing the braided line and either replacing or attempting to straighten it out will be your best bet.
b) If the supply is copper, you will have to cut the line cleanly and carefully. you will then most likely need a 1/4" or 3/8" compression/quickconnect BY 1/2" IP fitting to complete your repair.
2. Other possibilities include:
a) Failure inside the faucet body which will most likely be warrantied by Grohe if you push them hard enough.
b) A problem at your hot water tank, most likely the outlet side and *perhaps* you hadn't noticed the problem elsewhere.
c) The hot valve failing to reopen fully despite all appearances; applies if you turned off the water under the sink for your repair.
I have a brand new Europlus faucet with hardly any water flow. I had the first Euro faucet with good flow. Why is the water flow so low on a brand new faucet.
when you installed did any teflon tape or debris get inside? you can remove and reverse flush with hose and it may clear the blockage
2answers
Low water flow and pressure
remove aerator and cart. and soak in limeaway over night
Top Grohe Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Grohe Home Expert? Answer questions, earn points and help others
