Hi I'm trying to run my chkdsk program but was not successful. I ran it as administrator and got the following in the command prompt.
"The type of the file system is NTFS. Volume label is SQ004328V04
WARNING! F parameter not specified Running CHKDSK in read-only mode.
CHKDSK is verifying files (stage 1 of 3)... Attribute record (128, "") from file record segment 28ed) is corrupt 185792 file records processed. File verification completed. 820 large file records processed.
Errors found. CHKDSK cannot continue in read-only mode."
I've done some research trying to find a solution but no such luck. Any thoughts? Thanks in advance!
okay I typed in "chkdsk /F /X :c" and it did the same thing as when I click on the icon. The command prompt screen flashes for an instant and then vanishes
another update, I managed to pull off a quick print screen when the command prompt flashed and it says my access is denied and I need to "invoke this utility in an elevated mode." Is there a way to enter the run command and simultaneously invoke it as administrator?
You can't post conmments that contain an email address.
C:\Users\Niko>CHKDSK /F /X C: The type of the file system is NTFS. Cannot lock current drive.
Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N) Y
This volume will be checked the next time the system restarts.
C:\Users\Niko>
Open cmd
This is a regular problem on Win XP computers. They are old so the hard drive is also old. You may need to do a reinstall of your operating system. But you could try running RKill first it is a rootkit killer. This may find the problem in your software, but don't hold your breath, With chkdsk failing it is a reliable indicator of a physical failure on the hard disk. You need to consider that a hard disk is metal plates spinning very fast and while they are designed to take some knocks, over time a laptop takes more knocks than you would expect. The plain truth is, stuff breaks and need s replacing.
I have run chkdsk /f (which is check disk fix) and I have run chkdsk /r (check disk repair) but I have never heard of trying both switches at the same time. I suggest powering off the machine (hold down power button) than restarting and running chkdsk /f first and if you still have issues run chkdsk /r which is a more in depth scan which can take a couple of hours depending on the size of the drive but never 15 hours in my experience.
As an administrator, bring up the command prompt window (click the Windows menu, select "All Programs" then "Accessories", right-click "Command Prompt" and select "Run as administrator). Into this window type "chkdsk/f" and press ENTER.
To run Disk Check facility, you must run elevated command prompt and type 'chkdsk' and press enter. Now windows itself will try to figure out any problems related to your hard disk.
Note: To run elevated command prompt, go to "cmd" or "Command Prompt". Right click over it and select "Run as administrator". Now the window of command prompt in administrator mode will open.
above statements are right you may also run disc defrag to your system click start/controlpanel/Administrative Tools/computer management/storage/disk defragmenter then select or highlight the drive where your operating system is installed click defragment
You may run or perform Disk Error Checking(This is for Windows XP SP3):
* Chkdsk (Chkdsk.exe) is a command-line tool that checks volumes for problems. The tool then tries to repair any that it finds. For example, Chkdsk can repair problems related to bad sectors, lost clusters, cross-linked files, and directory errors.
** How to run CHKDSK at the command prompt:
Click Start, and then click Run.
In Open, type cmd, and then press ENTER.
Use one of the following procedures:
To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
Note If one or more of the files on the hard disk are open, you will receive the following message:
Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
Once done with chkdsk r, run FIXBOOT and press ENTER.
Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
What is the exact problem you have with your Hard drive? Feel free to tell me, I am ready to help you fix it. you can as well perform this little troubleshooting yourself. Use the Chkdsk (Chkdsk.exe), it is a command-line tool that checks volumes for problems. The tool then tries to repair any that it finds. For example, Chkdsk can repair problems related to bad sectors, lost clusters, cross-linked files, and directory errors. To use Chkdsk, you must log on as an administrator or as a member of the Administrators group. You can also run Chkdsk from My Computer or from Windows Explorer.
How To: Fix Windows Built in Defragmenter Had the same problem, turns out that in SP2 you have to have "DCOM Server Process Launcher" enabled in administrative tools> services for the
·First open up a Command Prompt, this can be found at: Start -> All Programs -> Accessories -> Command Prompt
·Change into your windows\system32 directory. Your windows directory will be either windows or winnt. Type: cd \windows\system32
Register the defrag components, by typing: regsvr32 dfrgsnap.dll regsvr32 dfrgui.dll
At this stage, you may find the defragmenter works. If not, there is one more step you can do.
Using Windows Explorer browse to your windows\inf folder. In there you will find a file called dfrg.infright click this file, and select Install.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
