Dell Inspiron 6400 Notebook Logo
Posted on May 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Land drivers where can i get lan drivers for my dell Inspiron I6400. Is Boradcom 440 x 10/100 integrated controller, a lan driver?
Anonymous
Level 2:
  • Expert 135 Answers
  • Posted on May 01, 2009
Anonymous
Expert
Level 2:
Answers
135
Questions
0
Helped
133683
Points
492
Www.dell.com support enter servcie tag and download appropriate driver
My Dell Inspiron Integrated WebCam doesn't Funcion anymore , What to do please
Based on the information you have provided, it seems that the issue might be with the webcam driver.
You may first try re-installing the webcam driver.(Please find the driver download link below)
http://downloads.dell.com/app/DELL_WEBCAM-SOFTWARE--MS-INB_A00_R250373.exe
Hope this helps..
Dell Inspiron 1464 WebCam not working any more..
older, end of year 2017 post unanswered,
sure, and is good post. too, lots of facts told by you. VG !
PC model stated, Very good,
OS, w7-64 (amazing you are like 1 in 1,000,000 post with this fact)
here is your answer, as is true for all PCs made
you first need the USB drivers in the PC working prefectly or the camera will be dead
then the DELL drivers for this this exact PC loaded, and only DELL has those, not fixya, nor MS< nor others.
only DELL.com has them.
amazing fact 2nd google hit lands me here
http://www.dell.com/support/home/us/en/04/product-support/product/inspiron-1464/drivers
go there, run the detect,
or load all the correct driver there and it will work
unless the PC is infected with virus, as that kills anything,.
did you upgrade from VISTA ,if yes, that be #1 first fact to tell.
for sure. and if yes, HOW?
How to turn on webcam in my dell inspiron 1525. but i have default cam driver installed in os. tell me the solution.
Is the webcam being recognized in Control Panel/Device Manager - under 'Imaging Devices'?
Have you tried reinstalling the webcam drivers/software you might have received with the laptop?
You can download the latest versions from the Inspiron 1525 from this link Drivers and Downloads
The Dell 'Webcam Manager' software is listed under 'Applications', and the drivers are listed under 'Input Device Drivers' (integrated webcam).
Select the appropriate OS version (i.e. Vista 32bit), download and install those two (drivers first)
Note: When you click the respective download links, don't use the Dell Download Manager!! It's known to cause various problems. Use the 'download in internet browser' option instead.
1helpful
How to replace broadcom 440 card on inspiron 6400
The Broadcom 4401 NIC is integrated into the motherboard. so you can either replace the motherboard (Around $150 on ebay)
http://shop.ebay.com/i.html?_nkw=Inspiron+6400+motherboard&_sacat=0&_odkw=I6400+motherboard&_osacat=0&_trksid=p3286.c0.m270.l1313
or get either a ExpressCard NIC or a USB NIC
http://www.newegg.com/Product/Product.aspx?Item=N82E16839314004
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2050400027%201162810710&name=USB
5helpful
I formatted my dell inspiron b120 model laptop i need lan driver
Here is a link to the Network Driver:
http://dsn.us.dell.com/DSNCR/DSNGateway?target=GetDocument&objectID=0E2392E739334481872AE06262A4FC10&languageCode=EN&regionGuid=DD4C7CB26E136815E030A68F27285B52&open=1
Dell Inspiron 5100
You can try checking the BIOS first see if its disabled in the BIOS to boot to the BIOS turn on your computer Press bios2.jpg during POST to enter the system setup program.
once in the BIOS you might have a multi page view, or a one page view, look for the INTEGRATED NIC see if its enabled or disabled. just enable it and restart the system then:
download
LAN CARD DRIVER
http://ftp.us.dell.com/network/R54631.EXE
see if it works. hit me back with the result.
1helpful
Dell inspiron I6400 touch pad is not working
Unless there is not a hardware switch and the only manufacturer that I know of that did that was Compaq/HP about 5 or so years ago. Typically there are no drivers to be installed for a mouse (touch pad) as a generic set is in the driver library of the operating system. 9 times out of 10 it is a hardware failure. With that being said, if it has warranty send it in, if it does not, (although it may just be a loose connection or the touch pad itself) most repair shops are going to run anywhere from 150 - 300 dollars just to crack it open. Best option is to get a small USB mouse, unless you just really want the touch pad.
2helpful
2answers
No sound in my Dell Inspiron 6400 laptop
If the issue is no sound after reinstallation of Windows, then your issue is most likely a driver issue. Many items in the system will function with native windows drivers but the audio on a I6400 is not one of them. Installation of drivers in the correct order is critical to Dell portables functioning correctly. Correct driver order is:
Notebook System Software.
Chipset Utility
Video Driver
Audio Driver
Modem Driver
Network Driver
Wireless Driver
Touchpad Driver
Quickset Utility
All other applications and drivers (MS Office, Printer driver etc)
This system is also equipped with Media Direct capability. For Media Direct to function, the system's HDD must be prepared using the Media Direct installation CD, then WIndows installed, then the Media Direct application. If you have no plans to use media direct, this can be skipped (Most people do)
Wireless internet problem
Hi
I think your Operating System (OS) software installed after formatting does not have drivers for the wireless network card.
You did not provide any clues about the OS and the Network (Model/Brand) installed.
Dell Inspiron 6000 did ship with Windows XP as the Default OS and Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card or Intel PRO Wireless 2200BG, 2915ABG Wireless LAN Mini Cards as options
First, check the Original System Configuration to find out the built specification of the Inspiron 6000.
Enter you system tag. Click on the Original System Configuration Tab. Check the factory built specification and note the Wireless Card installed from the factory. If you have not changed or upgraded the Wireless Card, download and install the drivers from the list below.
Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card Drivers
Intel PRO/Wireless 2200BG / 2915ABG Wireless LAN Mini Card Drivers
I am almost sure you will need drivers for the Chipset, onboard network and video.
Intel Mobile Chipset
Broadcom 440x 10/100 Integrated Controller Driver v.4.25
Video (as above check the factory spec if you ordered the ATI MobilityRadeon X300)
Intel Graphics Video (onboard) Driver v.6.14.10.4609
ATI MobilityRadeon X300 Driver v.8.162-050803a2-025823C
Let me know how you get on.
Mike
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
