Like any good electronic stability system, the StabiliTrak is designed to make driving safer by helping the vehicle to stay on its path when going around corners. What happens is as a driver heads to fast into a corner, the tires can't grip the road and sends the vehicle either skidding or spinning out of control. Now the StabiliTrak system, using a complex set of sensors and a controller, sends a quick series of pumps to the individual brakes to help the vehicle pull out of the turn and stay straight on the road. The sensor can measure the difference between the angle of the steering wheel and the direction you are actually turning. Then, as defined by the situation, it uses precise for precision pressure on the right brakes to help the driver stay in the right direction. The entire process happens so quickly that the driver's won't really know that it is going on. They won't even recognize the need for a correction in the steering it happens so fast. If they do suddenly recognize that they are heading into the corner too fast and pounce on the brakes, the system will still be able to detect and deal with the uneven braking problem.
The limited edition brings memory setting for mirrors and seats, it recognizes which key are you putting in the ignition and puts the saved setting accordingly to that driver's key. That is the reason your seat keeps moving. You need to reprogram the seat position for that key. Good luck
suspect tempreture sensor on drivers side. it seems to send a signal that this side of the car is too cold.
if you have duel setting so driver can control both sides at same time set also to air and see if it jumps to heat on both sides, if so there seems to be an electical problem with the tempreture contoler.
