RCA RS2534 CD Shelf System Logo
Rob Carr Posted on Oct 31, 2013
Repair parts Need CD drive belt, or specifications for substitute.
2answers
I need 2 belts for my Craftsman utility sharpener part number or90109. Where can I find them?
Sears web site will give you info re getting parts for craftsman products.
Where can i buy a replacement burner ?
Depending on the problem, you may not need one. I always consult RUss at New Jersey Factory Service first. He has repaired the ones I had at Radio stations before. There are some models that require only the manufacture change the CD section. That is probably because they have no original parts and have to jury rig or substitute the part. If there are no parts and it is past 7 years, they might say no more parts and that will be that. Contact Russ.
1helpful
No arranca windows por el problema de windows root\system32 \hal.dll.
Hi! Welcome to www.fixya.com.
You need to get an Windows Operating system XP
Option 1:
Boot from your CD and follow the directions to start Recovery Console. Then:
Attrib -H -R -S C:\Boot.ini DEL C:\Boot.ini BootCfg /Rebuild Fixboot
Option 2:
Boot from your CD and follow the directions below to start Recovery Console.
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD. When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console. When prompted, type the Administrator password. (if you didn't create one try pressing enter).
At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
Most likely you will need to expand the file from the CD. The command would be expand d:\i386\hal.dl_ c:\windows\system32\hal.dll. Substitute d: for the drive letter of your CD. Once you have expanded the file type "exit" to exit the Recovery Console and restart the computer.
TIP: Recovering Windows XP using the Recovery Console
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
1helpful
Does anyone have a free PDF 1995 Dodge Caravan SERVICE MANUAL?
DODGE CARAVAN 1991-1995 SERVICE REPAIR MANUAL
DODGE CARAVAN 1991 1995 SERVICE REPAIR MANUAL Download Manuals Technical
COVERS ALL MODELS & ALL REPAIRS A-Z
This a complete service manual. It covers almost every detail on your car. All models, and all engines are included!
This manual is the same manual that is given to your local service/repair shop.
The PDF allow you to zoom in for to view
detailed parts and then print out any pages you need... without
GETTING GREASE ON ANY PAGES.
Covers in detail , THOUSAND OF PAGES....ALL
for easy, detailed viewing.
WORKS ON ALL COMPUTERS - PC & MAC
I have listed below the main categories that can be found in our manuals. You can expect many more sub categories in any manual we offer!
COVERS
*ENGINE OVERHAUL AND REBUILDING *BRAKES *SUNROOF
*TIMING BELT REPLACEMENT * TROUBLE CODES
*WIRING DIAGRAMS *TROUBLESHOOTING AND DIAGNOSTICS
*ENGINE PERFORMANCE *FRONT END PROCEDURES AND
SPECIFICATIONS *SUSPENSION
*TRANSMISSION INFORMATION *AIR CONDITIONING SERVICE
AND CAPACITIES
*COMPUTER DIAGNOSTIC CODES
*FIRING ORDERS *DETAILED SPECIFICATIONS COVERED
*FACTORY MAINTENANCE SCHEDULES AND CHARTS
*SERPENTINE BELT ROUTINGS WITH DIAGRAMS *TIMING BELT
SERVICE PROCEDURES
*DRIVING CONCERNS
*COMPLETE TORQUE SPECIFICATIONS
*U-JOINT AND CV-JOINT SERVICE PROCEDURES
*REPAIR PROCEDURES *COMPLETE WIRING DIAGRAMS
*HUNDREDS OF ILLUSTRATIONS
AND MORE...
FORMAT: PDF
LANGUAGE: English
COMPATIBLE: Win/MAC/Linux
* DOWNLOAD
* NO SHIPPING COST
* NO NEED TO WAIT FOR A CD-ROM
The ONLY Service Repair Workshop Manual You Will Ever Need!
Download means there is NO shipping costs or waiting for a CD or paper manual to arrive in the mail! You will receive this manual TODAY via Download on completion of payment via our secure payment processor. We accept ALL major credit/debit cards/Paypal
DO THE REPAIRS YOURSELF AND SAVE $$$
1helpful
Disc belt needed
You need only measure the diameter in MM and put that and "CD/Cassette drive belt" into google and you should find a supplier. A few MM either side shouldn't make difference. Drive belts etc are none specific makers by the way.
Difficulty to open cd rom o my pc how to solve?
Repairing your Optical Drive problem isn’t that difficult task.
Unfortunately you have failed to prove the Manufacturer Name and Model Number of your particular specific CD-ROM Optical Drive so I am unaware of what particular specific CD-ROM Optical Drive information to provide.
However if you use Google Search (http://www.google.com) and search the topic Repair CD-ROM you will be able to obtain information on how to disassemble and repair your specific CD-ROM Optical Drive. Examples of a Google Search are provided below ->
http://www.repairfaq.org/sam/cdfaq.htm
http://repair4laptop.org/notebook_op...cd_dvd_mo.html
http://www.repairfaq.org/REPAIR/F_cdfaq9.html
The most difficult part of the repair will be finding the correct size replacement 0-Ring that fits your particular specific CD-ROM Optical Drive. You could try checking with local Computer Repair Shops and see if the have a broken CD/DVD Optical Drive that has the correct size 0-Ring that might work in your particular specific CD-ROM Optical Drive.
On another note now days Optical Drives are inexpensive and you can obtain a replacement CD/DVD Optical Drive for less than 30 bucks.
Hope it helped you. Thanks.
2helpful
Need drawer belt for Yamaha CDC-805 CD changer - the one needed that opens and closes the changer's door - not sure where to get it or the part number. I thought I ordered the right one and got the 'drive'...
Any decent repair shop should have a large supply of replacement belts. The Part number isn't necessary. Just take the old one in and get a new one just 2mm smaller than the original. Some repair shops won;t sell them because they don't want you repairing your own property but a decent shop should sell you one.
I am replacing belt on kenmore dryer but the new one from lowes seems to small are there multiple size belts for kenmore?
You need to match the belt to the specific make and model of dryer. There are several online appliance repair parts suppliers that can provide great assistance, and in some cases, the OEM part number for the belt. With the latter, appliance outlets like Lowes should be able to verify that the belt purchased is the part needed. In addition, check your owner's manual for a specific part number for the drive belt.
Onkyo Help needed !!!!
For the belt, you might check out www.mcmelectronics.com they even have assortment sets.
Geno
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
