SOURCE: picture is not coming on samsung spn4235
Remove the Power Supply cable to Y Main board and check the Vs voltage in Power Supply board.
1. Vs voltage is OK, replace the Logic board or Y Main board.
2. Vs voltage is NG, replace the Power Supply board.
SOURCE: samsung plasma no picture sound works
I know you don't wanto hear this but, PRO shop. As who knows what burned. I foyu rnot famailar with this stuff you'll waste time and money, Pro Shop or get another LCD with 120HZ
SOURCE: samsung plasma 42 inchs with sound no picture
Most likely your Y Sustain panel has gone bad. I would have a qualified service center evaluate it to be sure.
SOURCE: samsung 50" has sound no picture no menu etc.
Check the power cable feeding the power to th PC
SOURCE: samsung 50" plasma tv with no picture but has sound.
I just had a similar issue with my 46" Samsung LCD and fixed it myself for $5.11! I realize we have different tvs, but I bet it is the same issue ... crapped out capacitors.
I researched the problem online and most places, like samsung's site, referred me to call a repairman and called for the whole control panel or power supply to be replaced for anywhere between $400-$1000. I was like ... "screw that" ... I refuse to put in a fautly part in the place of a faulty part. So I continued to research.
That's when I stumbled on youtube. There are many how to videos on how to tackle this daunting task. I read that the issue was more than likely faulty capacitors and there is a very easy way to tell if it is in fact the capacitors that are blown. instead of having a flat top, faulty capacitors are crowned or even ruptured! When I opened up my TV I saw 3 blown capacitors!
So I bought 3 new capacitors all with the same uf and higher volts ... I think all three of my capacitors were 1000 uf and 25 volts. I kept the uf the same (recommended) and raised the voltage to 35 volts. It doesn't mean more volts, it just means it COULD handle more volts if it had to (which was the problem those cheap Samsung bastards screwed up on). This is a very common problem with Samsung TVs.
Anyway, I have never soldered before, but I did it. I warmed up the solder on the bad capacitors and removed them them slid thenew ones in and soldered them in and popped everything back together ... and PRESTO .... the damn thing works better than ever!
3 capacitors= $5.11
1 solder gun and solder= about $18
fixing an incredibly intimidating TV by yourself= PRICELESS!
Seriously ... don't be afraid to F up ... check it out on youtube and other place and save yourself a bundle.
Source(s):
I just fixed my TV!!!!!!!!
