Connex 3300 240-Channels Base CB Radio Logo
g
gerald dodge Posted on Oct 25, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a connex cx3300hp i need to know the vr adjustments for meters and power and i dont have no modulation please help me jerry.? thank you.
Mike Charette
Level 3:
Genius:
  • Connex Master 1,847 Answers
  • Posted on Mar 20, 2016
Mike Charette
Connex Master
Level 3:
Genius:
Answers
1847
Questions
Helped
490657
Points
2212
There is a modulation transformer in the radio.You should see a variable close to it.If you turn it to the right you will see your modulation either go up or down If it goes down then turn it the other way.
dustin milvert
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 31, 2013
dustin milvert
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
787
Points
I have a 10k on a quad mag mount my radio is a galaxy 98vhp peaked and tuned and i talk every where i key on base stations no problem that antenna is a beast you have some issues goin on over there u need to get that tuned i have a flat 1.0 and i run around 250 true watts and my swr never goes past 1.1 you wanna be loud n talk tune that puppy right biggest thing for them is ground best thing is to run it on a huge magnet best ground there is and you have to have good coax that has alot to do with it just tiny little things you have to check make sure everything is set up correctly
1 Related Answer
Gavin93
EDACS
  • 66 Answers
  • Posted on Jul 02, 2008
SOURCE: adjusting the vr pots
A word of advice, never buy a radio second hand. Used radios are sold for some odd reason, and it may be because it is broken. And yes you can do it with your meter, you just have to tune the radio using Coarse and Fine adjustments, also use peaking if you know how, to get a better transmit and receive.
Ranger PPR-RBT1
Tommy, I know why you like the radio, but I must warn you that it isn't type accepted for the amateur band. (it would be the same thing as using an amateur radio for the fire department or sheriff for emergency uses.) I have looked for the mods to change it into a 10-meter radio, and they are not to be found. My suggestion to you is to look in a recent issue of QST about building a Bluetooth (c) transceiver for your regular 10-meter radio. I had to do the same thing for my HF rig which happens to be a Yaesu FT-857D. Fire me an e-mail if you want the schematics for the box. 73 and good luck!
2answers
Cb radio modulation
www.cbtricks.com
use the vr adjustment points to adjust the AMC modulation. DO NOT cut the mic audio limiter tr-32 or the modulation limiter tr-54. it will over-modulate and splatter out of band if you do
My connex cx3300hp wont transmit
You need external watt meter& SWR meter..Change antenna..Is the radio meter keying 3/4 way up to 4 watts?(if not then its not Tx'ng)It could be 10.240 mhz crystal or IF pots(need Frequency counter) Or take it to professional Cb repairmen...
What kind of meter is needed to check modulation on cb radio
astatic 600.It has 3 windows for SWR, Power handles up 5000 watts and modulation cost about 120.00
How do peak and tune my 4300 dxl
modulation cut r249 & r246 these are limiters no limiters loud modu this radio is the same board as the 3300 connex
am low power adj vr 13 high power L 32 L 33
1helpful
2answers
How do you set regular channels and low and high on a connex 3300
Combination of hi / low switch and the band knob, I believe C band with the switch on low will give regular channels.
5helpful
2answers
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
1helpful
Does anyone know the pod too turn for lowering the watts on my connex it is too high and i would like to turn it back also the modulation thanks
You have to adjust the high key first so make sure you're rf power is on high, hope you have a meter set it on the 20 watt scale, key up and turn vr 13
located in back of radio infront of where you're coax connector is until it keys around 12 watts, thats where most connex 33hp should be set,now go to low power and key adjust vr 16 right net to the otherone down to about 3 watts, now you can drive a liners. Mod is Vr 2 right below them two. whistle in mic and turn to get the mod you want.
Adjusting the vr pots
1helpful
Audio limiter
tintlady, here is the info you requested;
the AM limiter is R 276
These are the variable adjustments inside,and what they control.
VR-1 AM S-METER
VR-2 SSB S-METER
VR-3 SSB SQUELCH RANGE
VR-4 AM SQUELCH RANGE
VR-6 SSB CARRIER BALANCE
VR-7 TX OFFSET
VR-9 RF METER
VR-10 FINAL BIAS
VR-12 DRIVER BIAS
VR-13 SSB ALC
VR-14 AM HIGH POWER
VR-15 AM MODULATION METER
VR-16 AM MODULATION
VR-17 SSB POWER
VR-18 AM LOW POWER
VC1-10.240 MHz Frequency adjustment
Hope this helps you out, let me know,,Mechanic
Top Connex Radio Communications Experts
ADMIN Andrew
ADMIN Andrew
Patrick Patterson
Patrick Patterson
Level 1 Expert
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
