20 Most Recent Connex 3300, Deluxe Amateur Transceiver, 40 Channel AM/FM, Digital LED Indicator Questions & Answers
www.cbtricks.com
use the vr adjustment points to adjust the AMC modulation. DO NOT cut the mic audio limiter tr-32 or the modulation limiter tr-54. it will over-modulate and splatter out of band if you do
Connex 3300,... | Answered on Apr 28, 2018
I just answered that in the link below
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=89&fml=0&brd=3150&thid=23542883
Connex 3300,... | Answered on Jan 10, 2016
buy yourself an astatic PDC-5 antenna matcher and use it to get your match to a 1.5:1 but before you do that is your antenna one that can be tuned by sliding it up or down if so and you can't get it any lower than 3 then get the PDC5 only about 24.00 plus S&H
Connex 3300,... | Answered on May 18, 2014
if your swr is higher on 1 then on 40 then your antenna is electrically short and you have to lenghten the antenna.If it is higher on 40 then on 1 then it is long and you have to shorten it. If you have to make it longer then you may have to add a quick disconnect or a coiled spring to make it longer. To make it shorter all you have to do is trim a 1/4 in at a time off the antenna whip but you must keep checking the match until it gets down below 1.5 .
Connex Radio... | Answered on Oct 03, 2018
Have you tried keying it without the coax attached ? Take the mic apart and give it a squirt of electrical parts cleaner .Try using a different mic also.
If you disable any part of the radio that does not pertain to CB then you could actually do damage to the radio. the best thing to do is leave it on the CB band and don't touch it.
the radio is searching for a strong incoming signal and until it gets one it will search for one. Try turning off the scan button .
many trucks have a ground wire in the harness as the cabins are fibre glass or not grounded around the cabin mounts If the radio grounds out through the frame , then there would be no ground for the radio or the aerial wire
to fit this particular may require such a wire in the harness for the radio which it probably doesn't have
As you have been alerted to a problem, it would be advisable to talk with professional radio fitters who work on trucks to get the correct advice before starting on the job
it could save a lot of frustration
Connex Radio... | Answered on Nov 23, 2017
Connex 3300, Deluxe Amateur Transceiver, 40 Channel AM/FM, Digital LED Indicator Logo
Popular Tags
4 questions posted
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Connex Radio Communications
Most Popular Question
cb radio modulation
  • Radio Communications
