If you have not format completely you may find restore point... If not visit this page http://en.kioskea.net/download/download-1321-windows-vista-sp1 download and burn it to disk or make a bootable USB then install it and it may not require serial, if required try to activate with your original serial..
If you did not make the system disks when you first got the computer then you will need to find the disk somewhere else (unfortunately my disks wouldn't read properly). I just fixed my old vista laptop hard drive crashed. I found the same version of Vista Home Premium in a torrent file on the internet - burnt the disk and installed on a brand new HDD I bought on ebay - used my Vista registration code - might get slammed here but I as I used my original registration code then I can't see how it is pirating.....
SOURCE: can i keep new windows 8 pro after fresh fujitsu factory settings
There is a possibility that the restore partition has been formated by windows 8, depending on the type of install that took place.
You may be able to order the restore disks from the Manufacturer support section. You can contact FUJITSU technical support staff at 1-800-8FUJITSU.
Good Luck
