Sunbeam Twin Electric Auto Heated Blanket- Mushroom BW9800-030-772 Logo
S
Sharon Posted on Oct 23, 2013
How do I reset my electric blanket? - Sunbeam Twin Electric Auto Heated Blanket- Mushroom BW9800-030-772
1helpful
ON MY JASON ELECTRIC BLANKET I HAVE FLASHING P WHAT DOES THAT INDICATE CAN I RESET OR DOES IT INDICATE THE BLANKE IS DAMAGED IN SOME WAY AND I SHOULD NO USE
That means the unit is not plugged in from the control to the blanket. If you have it connected, then the element in the blanket or one of the thermal safety features is open.
Apr 25, 2018 • Home
I cannot get the f to come off so I can get the blanket on
Sometimes unplugging the blanket from the wall plug causes it to "reset"
1helpful
Se My blanket is blinking F2 and I can't set the controls
To reset the control:
1) Unplug the blanket from the wall outlet.
2) Check that the control is well connected to the module. (Disconnect and re-connect it).
3) Plug the power cord into the wall outlet.
4) Set the control to "on".
Try 1-4 three times. If the blanket still does not operate, disconnect the power cord and contact Sunbeam Customer Care at 1-(800) 892-7684.
1helpful
Cant find the flag tag to reset my electric blanket control
E4 error code beautyrest electric blanket
beauty rest electric blanket error code - akaQA
www.akaqa.com > Uncategorized
beauty rest electric blanket error code. What does error code E4 mean? Answer this. 0 Views: 2487 Answers: 1 Posted: 3 years ago. Comment this question.
E4 error code beautyrest electric blanket - Fixya
www.fixya.com/support/t22178587-e4_error_code_beautyrest_electric
Dec 13, 2013 - E4 error code beautyrest electric blanket One side works the other returns an "E4" error code - Simmons Beautyrest Microfleece question.
Sunbeam electric blanket repair waynesboro ms
wash the blanket then throw it in the bin
water and electrical components do not mix
electrical blankets are just a resistor element in ceramic covering and if you put that in a washing machine that is the end of the insulation
3helpful
3answers
Electric blanket controller light blinking
i had the same problem , i believe it was caused by unplugging the blanket plug while it was in the on position , i unplugged it from the wall and it like reset itself , worked for me.
Top Sunbeam Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
