Question about Wolf Range Ovens
SOURCE: Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 26, 2010
Testimonial: "This advise seems right on. Thanks for your fast and detailed advise. Steve"
SOURCE: why does it take so long to preheat.
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 26, 2010
SOURCE: Oven takes forever to preheat
check to see if both broil and bake elements/gas works
Posted on May 27, 2010
Apr 22, 2016 | Ovens
Dec 20, 2014 | Fisher and Paykel AeroTech Double OD302...
Hi friend, thank you for your post!
I know from your post that your Frigidaire oven is working but the preheat takes 30 minutes. This does sound like lengthy amount of time for preheat to be completed. From what you are describing it could be an issue with the panel, element, or thermostat. Since it could be anyone of these underlying issues I would recommend having a professional come out to diagnose your refrigerator to determine the root cause to reduce the risk of unnecessary parts. -Matt
Aug 06, 2014 | Frigidaire 30 in. Electric Gallery Series...
May 25, 2010 | Maytag CWG3100A Gas Single Oven
Apr 28, 2010 | Wolf Range WKGD-2 Gas Double Oven
Mar 14, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
Jul 12, 2009 | Ovens
Mar 10, 2009 | Whirlpool RBD305PD Electric Double Oven
Jan 16, 2009 | Wolf Range WKGD-2 Gas Double Oven
Dec 15, 2012 | Wolf Range Ovens
393 people viewed this question
