20 Most Recent Frigidaire PLEB30T9DC Electric Double Oven Questions & Answers
Google what you need using the brand and model. It should also be in your instruction manual. Most of them you just close door securely and click the self clean to on. It knows the cycle and for how long.
Frigidaire... | Answered on Feb 25, 2013
Hi you probably might just have an oven limit that is open
To test that you would set your oven do these tests:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Frigidaire... | Answered on Dec 07, 2010
Sadly ours performs this way also. I've always had GE wall ovens and NEVER did they take very long to get up to temperature.
Has anyone else communicated with you about this problem?
Frigidaire... | Answered on Feb 01, 2010
Height is determined by the available space and the desire of the owner. There is no standard as far as I have ever heard. Eric
Frigidaire... | Answered on Jul 08, 2009
what you are describing is the cooling fan. That fan will come on to keep the electronic control panel cool. It is normal for tat to come on even if your done with the oven. I dont think is should be as loud as you describe. I would try the oven again and if it is still loud I would call for service because it is new. That fan will also come on when you use the self clean cycle.
Frigidaire... | Answered on Jul 26, 2007
PF means power failure. This is a loss of power that may be inside the stove or it maybe an issue with the wiring in your house. The biggest threat would be the wiring in your house and you should call an electrician to check the breaker panel and outlet. If it is not that, then you can look for a loose connection inside the stove.
Frigidaire Ovens | Answered on Jan 07, 2021
The replacement EOC could be defective or installed incorrectly.
Frigidaire Ovens | Answered on Nov 08, 2020
SOUNDS LIKE YOU HAVE A JEWISH MODEL PERHAPS IT IS IN SABBATH MODE
If it has been awhile since the self clean function has been used grease from cooking can build up on the inner contacts of the oven control. This would either need to be replaced or taken apart and cleaned. The self clean function should either be used more frequently or not at all,
Frigidaire Ovens | Answered on Sep 24, 2020
Try pressing and holding the Clear/Off button for 3+ seconds. The LOC indicates the control panel lock is enabled. The LOC should clear from the display. Note: if you hold the key pad for too long, the lock will reengage. From the picture of your range that you included, I believe this is the key pad button just below 7 to the right of the LCD display. There is a label in a small font just below the key pad. (The label probably is a padlock symbol and the word Controls but I can't resolve it from your picture.) Some newer Frigidaire Gallery ranges have a key pad button with a padlock symbol; this would be the correct button to press and hold on those models.
Warning: on some models, the door lock will also engage. Do not try to force the door open. Wait for 15+ seconds for the door lock mechanism to fully disengage before attempting to open the door.
I hope this helps.
Frigidaire Ovens | Answered on Jul 05, 2020
How to Reset a Frigidaire Oven
  1. Press and hold the "Bake" button for six seconds until "0°" appears in the display.
  2. Enter the lower temperature at which you want to reset the oven.
  3. Press "Self Clean" to reset the oven's internal temperature to a cooler setting
https://www.hunker.com/13409693/how-to-reset-a-frigidaire-oven
If your Frigidaire oven has a manual lock, slide the lock-bar to lock the oven's door. If it does not have a lock-bar, the oven will lock automatically. 3 Locate the "Clean" button on the oven's control panel. 4 Press the "Clean" button to begin the cleaning cycle.
https://www.youtube.com/watch?v=DSYUj3yGybY
Frigidaire Ovens | Answered on Apr 17, 2020
The F10 error can be caused by a faulty relay or electronic control board if the oven overheated while in use. If you unplug the range and the error occurs when the range is cool, then the over-temperature sensor has failed or the electronic control board is faulty. Even the wiring between parts could be faulty.
You need to check sensor and wiring. On some models, the oven temperature sensor probe can be accessed by opening the oven door. Look for two screws that are close together. Otherwise it's accessed from the back of the oven. It may be covered by an access panel. Unplug the wiring harness and check the resistance across the sensor with a multi-meter. It should give 1100 Ohms. Similarly check the wiring resistance from the probe to the control board. Also check the relay and that wiring. Replace the wiring, sensor or relay if those are faulty. Otherwise you need to replace the control board. The control board will be behind the console access panel. Somewhere on the back of the range, there will be a trouble-shooting sheet giving the wiring diagram and the expected resistance or voltage across the parts of the range.
I may be able be able to provide a parts diagram and price list for parts on your range. Please add a comment with the model number of the range for this information.
I hope this helps.
Frigidaire Ovens | Answered on Jan 04, 2020
First take out the broiler pan, insert and any aluminum foil. Remove any other tools or pans from the oven. Next clean any large deposits in the oven cavity with hot, soapy water and a cloth. Clean the oven frame, the area outside of the door gasket and the very front center of the oven bottom with soap and water. Once you are ready to start the Self-Clean cycle, press the Self-Clean touch pad. To change the length of the Self-Clean cycle, press the pad again, as needed. Press Start. If you want to have the Self-Clean delayed, press the Delay Start touch pad after the Door Loc message appears. Type in the start time with the keypad.
To stop this cycle, press Cancel. If the oven is hot, the door will remain locked.
Frigidaire has most of their manuals available on their support site: http://b2b.frigidaire.com/support/manuals.asp . The current link to the English version of the Owner's manual is http://manuals.frigidaire.com/PDFnotFoundCheck.asp?path=ftp://ftp.electrolux-na.com/ProdInfo_PDF/&folder=Lassomption&PDFtype=Owner&PDFfile=318205312en.pdf&model=FGEW3045KFB . See pages 24-25 for this information.
I hope this helps.
Frigidaire Ovens | Answered on Nov 05, 2019
Frigidaire PLEB30T9DC Electric Double Oven Logo
Popular Tags
8 questions posted
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Ovens
  • Frigidaire Ovens
Most Popular Question
height from floor
  • Ovens
