Paul, most likely a dirt carb, remove clean/rebuild carb."I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Just pull out plug w cable on and crank engine..shud see fire. If not then bad connect or magneto. I think u let engine set w ethanol gas n now carb is gummed. Always drain tank n float. U will need an outboard chemical at a boat shop to fix. Or carb needs overhaul
Go to the Briggs and Stratton website and go to their generators then to Generac. You should be able to track down a link to putting in your model number. (4) PDF manuals show for that model. http://www.generac-portables.com/service_support/owner_manuals/owner_manuals.cfm?rd=1
Check the pressure limiting bypass valve. Also make sure the replacement bolts are "rated". They must be a certain "grade" which defines their load rating. Make sure they are torqued to spec.
