My pressure washer will not start. I have changed the plug and cleaned the air filter. What is my next step. It seems like it is not getting a spark...how do I check...how do I know if it is getting gas. I have changed it
Just pull out plug w cable on and crank engine..shud see fire. If not then bad connect or magneto. I think u let engine set w ethanol gas n now carb is gummed. Always drain tank n float. U will need an outboard chemical at a boat shop to fix. Or carb needs overhaul
Testimonial: "I will give it a try, Thank You for your help!"
