Question about Generac 2700 PSI 2.3 GPM Gas Pressure Washer Non CA
Pressure washer surges - Generac 2700 PSI 2.3 GPM Gas Pressure Washer Non CA
Posted by jgarrett973 on
John Barlow
This could be your unloader valve taking in account the engine isn't surging. Does the engine run smooth? Do you have at least 50 psi water pressure feeding the pump? Inlet screen clogged? ALL tips act same way or no change?
Posted on Mar 26, 2014
I have a Black Max 2600 PSI pressure washer, model BM80913, that gives a surge of pressure, and then pressure drops off. Solution?
Pump needs to be rebuilt or replaced, some of those pumps have a replacement surge valve inside, some do not
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2094e122cc46f24c
Sep 27, 2017 | Psi Garden
Washer surges when trigger pulled
Check that your are getting proper water pressure. Also check filter going into the machine where the hose connects sounds like the washer is not getting enough water pressure.
Jan 06, 2011 | Karcher PSI Electric Pressure Washer
My Karcher K9.8 electric pressure washer started
Not Simple.
I have the same Problem, the leak is from the seam of the Manifold or on the pressure side of the Pump and the hose housing. In my case there is a small crack in the seam of the Manifold Housing. A manufacturing defect.. A New Manifold Complete Replacement about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 18, 2010 | Karcher 1750 Psi Elec Pressure Washer
Surges on and off when not in use
You must have a slight leak from somewhere like the trigger or hose etc. Any slight leak on the out pressure side will cause the machine to surge. If you don,t have any leaks then it will be a worn n/r valve on your pump.
Feb 14, 2010 | Campbell Hausfeld 1,350 Psi Electric...
The power washer is surging cuting in and out when i turn da nozzele to get stronger water pressure?
When I use my machine I hook up the water to the pump, hook up the high pressure line and gun, then turn on the water full and squeeze the triger to make sure all air is out before starting the pressure washer(mine is gasoline powered). Then I install the nozel on the spray gun. If you are having surgeing water pressure Check the hose washer where the water hose hooks to the machine, and be sure the supply hose is not restricted and valve is on full.
If this was helpful please leave Feedback. Thanks, SP
Oct 20, 2009 | Garden
When I squeez the handle the pressure surges.
Hi:
The first thing i would do is be sure there is not a partial blockage in the nozzle.
Sep 24, 2009 | Karcher 2500 PSI Pressure Washer
Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
When motor is at idle speed it surges
Try a simple test. It is ok to run the pump without water for a short time. Check idle speed without water in system to see if enginet surges. If it does not surge, then most likely the unloader/ pressure valve is causing the engine to surge when in the unloaded state. Life of unloader /pressure valve is shortened by letting system bypass for long periods of time. Enjoy
Nov 22, 2008 | Garden
Not enough pressure
Speed regulation on small engines is notriously fussy.
Check the linkage to the carburetor and look for a small, light spring.
If there are several holes for one end of it, you may have to try more than one to find the spring tension that lets the engine run steadier than it now does.
If not, then either replacing it or changing the length by shortening or lengthening it will probably be needed.
Aug 09, 2008 | Karcher 2500 PSI Pressure Washer
Generac 2700 PSI 2.3 GPM Gas Pressure Washer Non CA Logo
826 people viewed this question
Top Generac Garden Experts
Arnie Burke
Arnie Burke
Tom Chichester
jeff chenault
jeff chenault
Are you a Generac Garden Expert? Answer questions, earn points and help others
