Improved pulsed MIG or pulsed TIG output (ability to tailor the pulsed wave form). Depending on the application, pulsing can reduce heat input for less warping distortion or burn-through, improve bead aesthetics, reduce spatter, provide out-of-position puddle control and increase travel speed.
https://welderreview.com/100-amp-arc-welder-welding-soldering-machine-rod-110-volt-ac/
SOURCE: Need operating instructions for Thermal Arc 190 GTS tig welder
Try this one if not it go to the next link for manuals.
http://www.thermadyne.com/IM_Uploads/DocLib_2143_300X4838.pdf
http://www.thermadyne.com/thermalarc/component/option,com_doclib/task,/id,/Itemid,237/categoryID,4/
SOURCE: Is the arc force determined by the amount of
The voltage is controlled three ways, your manual setting you fine tune setting and the distance you have from the work space on most welders the fine tune only adjusts about 5 volts some newer models goes to ten but lets say 5 so if your running 7018 1/8 inch rod at 105 amps you may have to adjust it with the fine tune knob to half or 3/4 of the way to get the right flow pattern if using this pattern ccccc if your using zig zag so the distance is important it should not be more than twice the wide of the rod depending on what type of welding posting your doing overhead or vertical or flat position. If you need more clarification let me know.
SOURCE: Hi, starts to weld fine after a few seconds hi
It sounds like you need to change out your SCR chip on your motherboard; Miller makes one that i have installed on all our 350xl's, I don't have the number on hand but i can get it for you tomorrow.
Testimonial: "appreciate the help."
SOURCE: Ford f250 super duty V10 cruise control doesn't work.
WOULD CHECK BRAKE SWITCH FIRST AS THESE HAVE A HIGH FAILURE RATE.
SOURCE: I am using 3 Chauvet
1) Make sure to use a DMX terminator. (This is basically a XLR connector with a 120 ohm resistor soldered between pins 2 & 3)
2) Plug the cables in the DMX IN/OUT connectors... not the master slave one.
