SOURCE: Unit in room displays fault
Do not allow the signal receiver window to receive strong direct sunlight, since it can adversely affect its operation. If the signal receiver window is exposed to direct sunlight, close a curtain to block the light.
Using a Fluorescent lamp with a quick starter in the same room may interfere with transmissions of the signal.
The unit can be affected by signals transmitted from the remote control of a television vcr or other equipment used in the same room so make sure if anything recently added to the room is un plugged for testing purposes.
Do no leave the remote control in direct sunlight or near a heater also protect the unit and remote control from moisture and shot which can disclour or damage them.
Check whether the remote control batteries have become old and weak. (replace with new ones)
Try to send the signal again with the remote control pointed properly towards the units signal receiver window
Check whether the remote control batteries are installed with the polarites properly aligned
This could also be a result of the error locking out the remote as well so keep this in mind.
Also if possible unplug it and let it sit for atleast a day then plug it into a different outlet (if possible) to see if there is any change in the units functionality.
After that I would have to say check the area around the base of it and make sure that there is no moisture damage to the unit.
A good cleaning could be in order as well.
then if all else fails and the error presists contact customer service with the issue of the machine they will know what the error codes are.
hope that helps let us know how you make out.
SOURCE: the led panel on the
C6 - compressor run current high
- check [resistance of] compressor windings all equal 1 to 4 ohms
- check [resistance] to earth 50 Mohm minimum
- check run current
I'd also check the motor capacitor(s) , In maximum, it is due to weak capacitor. Replace and try.
