You may need to replace the rechargeable battery for your cell phone. Rechargeable batteries do not last forever.
Without knowing the make and model of your cell phone and without knowing where you reside, I cannot direct you to a source where you can purchase a replacement battery for your cell phone.
Only nemo fails, all other games ok all windows sounds ok,local mp3 files play dvd movies sound fails, tell us the extent of the failure first, if only nemo fails , then it's bad, not the PC. ok? Learnt that most folks trying to replace a driver fail,for many reasons, guessing tops the list as does blaming it IT IS WORKING CORRECTLY. 10000 of posts here like that, and now the PC has 2 failures.(one real, one self caused)
gee try dell, fixya is NOT DELL. Dell designed it not us nor microsoft, DELL did.
NO OS stated, is this XP? the virus magnet? what does funny mean? surely you can elaborate that.? (wish wish) sound from what object,external speakers, (powered)? FUNNY?= 1: dead.? 2: Weak? 3: distorted even with volume down)? 4: with all USB devices unplugged? (not mouse, not keyboard) do not use USB head phones or USB only speakers now. nor Blue tooth speakers now. just real speakers. for the test.(are you?) 5: what jacks, a desktop can have 2 green jacks./ one called (onboard and PCI sound "line-out") The green jack you pick if 2 there, must be selected in windows sound output screen.
tests? http://pcdied.com/no-sound/no-sound.html
I can have on my desktop, All these devices. ( i can select them) A: BT (blue tooth) B: USB head phones. C: main sound chip. Realtek D: main shut down in BIOS and PCI sound card.active. E: other head phones, or external speakers. F: mine now has a USB DAC box, that goes to home theater system. (fancy dancy)
Check with another headphone borrowed from a friend or try this on another phone and if the fault is similar the head phone is faulty. It can be failure of the wire- snapped- fault in the pin, or a damaged earpiece,
Error 76 can mean communication failure between tankless and remote control, which can include bad remote control, bad wire, bad wiring connector, or PC board failure. Disconnect remote control and see if tankless will work. http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Error C8 76 can mean PC board failure. Contact Rheem and/or service technician.
Take a moment and rate answer: And take advantage of fixya expert assistance live. For a price, expert works with you while you work on water heater or any do-it-yourself project. Fixya is always less expensive than a service call.
Eject the cd and check the optical head unit of the drive. If you notice any collection of dust or dirt on the optical head EYE then use a ear bud and softly clean the lens. Now place an CD and try , if the CD spins but does not detect then there is a failure of the optical unit or the drive.
You will need to replace the drive.
If the unit does not work it is possible that the power to the unit is faulty . check on the mother board for line failure to the CD drive..
Your CD drive has an internal failure which is usually the laser head. It would be cheaper to replace the drive or use your DVD drive to read CD's then to have the laser head replaced in the CD drive. The disk tray motor system is not connected with the read write system in the drive and the tray ejecting or loading a disk is not an indication of the health of the drives logic system or laser head.
How about trying with its internal speakers ?
if it works fine then the sound output jack-port have a problem.
If not working then try to re-install your audio drivers.
If still not having good result even if you re-install your operating system, you should go to repair center since you have a hardware failure.
I'm having the same problem as you. I just tried turning off the phone and head set, restarting them, and then following these instructions exactly:
http://motorola-global-eng.custhelp.com/cgi-bin/motorola_global_eng.cfg/php/enduser/cci/bluetooth_pairing_instrctns.php?p_headset=4224&p_handset=4662&p_cat=744
Seemed to work. For now...
