SOURCE: Dell XPS420 Freezes after being in sleep mode
Is there a reason why you cant turn off sleep mode and just let the screen saver kick in? You can do this by right clicking on your desktop and goto properties. Then ScreenSaver, then click on power.
Change these values to never and then go back and set your screen saver...
Hope this Helps...
Joe
DataMiner
SOURCE: Monitor keep going into "sleep" mode
try to reseat the memory modules and restart the computer and computer boots to normal mode/then go to power options in control panel and disable the sleep mode option for the hard disk
SOURCE: Computer goes to sleep before it even starts up
Hi there, it appears as though the Power Options are set too short a time and the PC is going into sleep mode. Go to Start menu/Control Panel and look for Power options. Set them all to "never" This will prevent her PC from going into sleep mode. Good Luck.
SOURCE: sleep mode problem
hey , first go to same mode in ur PC by pressing F7 .
thenblue window will appear so there select normal mode . thus ur PC will never go to sleep mode.
SOURCE: I have a dell dimension
Plug the monitor into another computer to determine if the monitor is damaged or working properly. You can also plug another monitor into your computer to determine the same thing.
