SOURCE: Can't get my iPhone to Pair with new Jensen SMPS-650
Hold botton down until it flashes blue AND then red it will continue To flash now pair ur headset
There are several things to try:
Remove and then reinstall the device:
Click the Start Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
Select the device that's not working, and then click Remove.
Click Add, press the reset button on the device
(or make it discoverable following the manufacturer's instructions), select the My device is set up and ready to be found check box, and then click Next.
If the device is not found, repeat the previous step.
When the device is found, select it, and then click Next.
Follow the rest of the instructions in the wizard.
Make sure the device is turned on and that the batteries don't need to be replaced.
Make sure the Bluetooth adapter for your computer is attached and turned on, and that the device is turned on and discoverable.
If you're not sure how to turn on discoverability, read the instructions that came with the device or check the manufacturer's website.
Make sure that you installed the device using the correct program. If not, reinstall the device.
For a printer, follow these steps:
Open the Add Printer wizard by clicking the Start Control Panel, clicking Hardware and Sound, clicking Printers, and then clicking Add a printer.
For a mobile phone, if you have Bluetooth wireless technology installed on your computer, use the Add Bluetooth Device Wizard. To do so, follow these steps:
Click Add.
For a keyboard or mouse, if you have Bluetooth wireless technology installed on your computer, use the Add Bluetooth Device Wizard. To do so, follow these steps:
Connect a wired keyboard or mouse to your computer.
Click Add.
The device might be out of range of your computer, or too close.
Try moving it closer or a little farther from your computer.
hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetoothview/3000-2648_4-10800572.html
Runs in the background, and monitors the activity of Bluetooth devices around you
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this will help you
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
