20 Most Recent Lenovo G570 43349EU 15.6" Windows 7 Home Premium 64-bit Notebook Questions & Answers
Go to lenovo.com click on support and then find your correct laptop, then find the manual and download it
Lenovo G570... | Answered on Jan 02, 2015
D3d is an abbreviated way of saying Direct3d. The 95 could possibly mean that it wants version 9.5, but I'm not really sure what else to make of it. Direct3d is something like a framework/library for rendering 3D objects on Windows operating systems. It's part of DirectX, but you can download direct3d alone from Microsoft; though I would advise against downloading it from any place but Microsoft or MSDN for several reasons. You can try grabbing the latest version (I think it's 11) first, and if that doesn't work, go ahead and look for 9.5.
Lastly, there's a possibility that this message means that your drivers are not compatible with Direct3d. There are a number of reasons this could happen. First off, your laptop may not be able to run Direct3d. However, I find this unlikely; it's pretty rare to see a Windows 7 laptop with absolutely no graphics capabilities whatsoever. If you ever re-installed Windows, that could be an issue, as the driver software is erased when you do this. It might be possible to ascertain additional information with a more verbose description of the problem you are encountering. ;-)
Lenovo G570... | Answered on Nov 08, 2013
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Lenovo G570... | Answered on Feb 14, 2013
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer If you still have no webcam installed Run the "Add a device"application, accessed by clicking on the "Start" button, opening the "Control Panel," and then double-clicking on "Add a device." The "Add a device" window will open and Windows will search for devices connected to your system but not installed. Click on the webcam name that shows in the search box and then click "Next." Choose whether you want Windows to search for the webcam device driver using Windows Update over the Internet, or if you'd prefer to have the device manager search for the driver using a disc supplied by your laptop manufacturer. Most drivers can be found on the system recovery disc included with your laptop, if you choose to add the driver from the provided disc. Place a check in the box next to your choice and then click "Next>" to continue. Wait while Windows searches from the driver using Windows Update, if this was your choice. An active Internet connection is required for Windows to successfully do this. Allow the computer to install the driver and then reboot the system for the webcam to become recognized by the system. Otherwise, you can use the system recovery disc or a driver downloaded directly from your laptop manufacturer to install the driver without using the Windows Update search feature. Open the CD/DVD-ROM drive and insert the system recovery disc, or place the driver downloaded from the manufacturer in an easily accessed file directory on your PC, such as on the desktop, or in your "My Documents" folder. Choose the option "Install the software automatically (Recommended)" in the "Add a device" application, and press "Next>" to begin searching for your webcam driver. The hardware wizard will search the system recovery disc and install the driver automatically. Press "Finish" to close the wizard and then reboot the computer to allow recognition of the webcam. Choose the option "Install the software manually" in order to browse to the driver location where you saved the driver and install it from there. Use the opened file manager and locate the driver. Click the "Next>" button to install the driver, then reboot the computer to add webcam functionality.
Lenovo G570... | Answered on Jan 29, 2013
which bluetooth device ? are you referring to ?
keyboard , mouse , ahh a webcam ?
Bluetooth is a wireless technology that connects devices over a limited-range network (WPAN, or wireless personal area network). Bluetooth transfers data three to eight times faster than a parallel or serial port.
Some Lenovo PCs includes an internal Bluetooth card to allow users to connect Bluetooth devices to the computer. Inactive Bluetooth support or computer settings can prevent the Lenovo PC from detecting a Bluetooth device.
Hold down "Fn" and "F5" after booting the computer or returning from standby to enable Bluetooth features. Click "Start." Click "Control Panel." Double-click "Bluetooth Configuration." Select the "Accessibility" tab. Check "Let other Bluetooth devices discover this computer." Select "All devices" from the drop-down menu. Click "OK." Double-click "Bluetooth Devices." Select the "Options" tab. Check "Turn discovery on," "Allow Bluetooth devices to connect to this computer" and "Alert me when a new Bluetooth device wants to connect." Click "OK." Exit from "Control Panel." Align the device with the Lenovo PC. Check the documentation included with the device to confirm it is the correct distance from the computer. Right-click "Start." Click "Explore" or "Open." Navigate to "My Bluetooth Places." Click "Bluetooth Tasks." Click "View Devices in Range" to locate the device. Select the device from the list. Click "Discover services" to use the device's applications on your Lenovo PC. Right-click the device and select "Connect" or "Pair" to configure the device. Hope it helps.
Lenovo G570... | Answered on Jan 25, 2013
I have gone through the product of yours and found out into the support page of lenovo the driver for the bluetooth. Please click here to download the file for your laptop.
You need to select the driver name as bluetooth and operating system as Windows7.
Thanks
Lenovo G570... | Answered on Oct 08, 2012
Thanks
Contact Lenovo support to inquire.
Lenovo Computers... | Answered on Jul 13, 2020
That depends on the country and model of laptop.
Lenovo Computers... | Answered on May 10, 2020
need to try cleaning it if that dont work replace it they are inexpensive
Lenovo Computers... | Answered on Apr 24, 2020
1) Turn on your mic 2) Start windows sound recorder 3) Start recording 4) Jam out on your instrument(s) 5) Stop recording 6) ... 7) Profit
In truth, this is a terrible device to record music on. You should look into getting a mixer (with as many tracks as you need) and a dedicated computer with a high quality sound card (M-Audio) is a good brand.
If you're thinking about making electronic music, look into FL Studio. http://flstudio.image-line.com/
More details would allow me to answer with more precision.
Lenovo Computers... | Answered on Apr 09, 2020
then you need to go see a computer repair service for a new battery possibly .
Lenovo Computers... | Answered on Mar 24, 2020
how to remove sim slot permanently lock in lenovo s90-a
Lenovo Computers... | Answered on Mar 12, 2020
Not a quick fix, but if it is a socket connector, you can take it apart and replace the socket. Check your local electronics components store.
Lenovo Computers... | Answered on Feb 15, 2020
Take it to a repairman. seems the screen VGA input has an issue.
Lenovo Computers... | Answered on Jan 20, 2020
Hello Jason,
The error message that u have mentioned seems that the virtual memory(page file) is less. please increase it from
Start>>Control Panel>>All Control Panel Items>>System.
On the left hand please select the option"Advanced System Settings".
In the System Properties Page select Advanced.
Under Performance option click on Settings tab.
In Settings select Advanced tab.you will find the option Virtual Memory
click Change Uncheck "Automatically manage paging file".
Now, Select your drive and click custom size and enter the minimum and maximum size from the details available in bottom under total paging file size.
click OK and restart your PC.
Lenovo Computers... | Answered on Jan 17, 2020
Settings - Display - Uncheck Mirror Display.
Lenovo Computers... | Answered on Dec 24, 2019
ask them yet, the actual makers,
no 2 PCs on earth reset the same way (bios)
https://pcsupport.lenovo.com/us/en/products/laptops-and-netbooks/flex-series/flex-3-1470
ask the maker, first.
Lenovo Computers... | Answered on Dec 17, 2019
Lenovo G570 43349EU 15.6" Windows 7 Home Premium 64-bit Notebook Logo
Popular Tags
13 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Toby Lee
Toby Lee
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lenovo Computers & Internet
Most Popular Question
determine rrect display parts assembly
  • Computers & Internet
