I installed adobe illustrator 10 and after it installed I double clicked it to open and an error pops up saying adobe illustrator 10 cannot run can you help?
Have you applied the Illustrator 10.0.3 update? It is supposed to fix some unspecified problems running on Windows. You should also make sure Vista has all of the current updates as well since they sometimes release application compatibility fixes with little fanfare.Have you applied the Illustrator 10.0.3 update? It is supposed to fix some unspecified problems running on Windows. You should also make sure Vista has all of the current updates as well since they sometimes release application compatibility fixes with little fanfare.
-Double-click the Adobe Illustrator icon on your desktop to open the program. Click the File drop-down and select the "New" option.
-Choose the size and color mode for the file and then click the "OK" button.
-Click the File drop-down and then select the "Place" option. Choose the "All Formats" from the Files of Type menu when the Place dialog box appears.
-Select the damaged Illustrator file and then click "Place." Enter a new name for the file and then click "Save." This will create a new Illustrator file with information from the damaged file. or you can try to use illustrator recovery , this is nice PAID service . i wish you good luck
How to repair illustrator file?Place the damaged Illustrator file in a new Illustrator file.
Important: This solution doesn't work if you didn't select Create Compatible PDF File in the Illustrator Native Format Options dialog box when you saved the original file. On the Macintosh platform, the damaged Illustrator file may appear dimmed in the Place dialog box, but you will still be able to select it and place it in the new Illustrator file.
In Illustrator, choose File > New.
Select the appropriate size and color mode, and then click OK.
Choose File > Place.
In the Place dialog box, choose All Formats from the Files of Type pop-up menu (Windows) or choose All Documents from the Show pop-up menu (Mac OS), choose the damaged file, and then click Place.
1. Run a full anti-virus scan. If possible, tell it to run the scan while the computer is booting up. Afterwards, try opening the program again. If it fails, try Step 2.
2. Go to Control Panel/Programs and features. Locate the list of installed programs and scroll down to Adobe. Click on Adobe and there should be an option to Repair or Uninstall. Choose Repair, if available. Otherwise, uninstall then re-install the software. (Sometimes, Windows Update is known to "break" an installed program; sad, but true).
Try:
Illustrator On-line repair service. Our service will analyze the contents of your file, the internal data structure of the *.ai file in an online mode using a combination of intelligent algorithms. It will then provide you with a preview of recoverable project data. The service features a very clean an intuitive interface, which makes corrupt Illustrator file recovery a snap even for novices.
Double click on My Computer on your desktop and open C:>Documents and Settings > User >Application Data > Adobe > Adobe Illustrator CS2 Settings.
(Your version of Illustrator will be in the foldr name.) Inside this
folder is a file called AIPrefs. Drag this file to the trash, and
restart Illustrator. Reset any custom preferences you want, and when you
close Illustrator the preferences file will be regenerated.
You can also reset Illustrator's preferences by holding down Shift + Control + Alt
while launching the program. If you get a dialog asking if you want to
delete the Adobe Illustrator settings folder, click yes to proceed.
Restart Illustrator. Reset any custom preferences you want, and when you
Save your work and close Illustrator. Double click on My Computer on your desktop and open C:>Documents and Settings > User >Application Data > Adobe > Adobe Illustrator CS2 Settings.
I have Windows Vista
What operating system do you have?
