Check your speaker terminal connection going into your laptop to make sure it is not shorting or falling out. Try using a pair of headphones to see if this issue is still present.
The only thing i can think of is the amount of power surging into the speakers is too great and they are cutting of to avoid blowing out. I have a similar issue with my surround sound if i turn it up too loud.
Not normal at all.....you can try the iPod Reset Utility that is located here...... http://support.apple.com/kb/HT1238 but I don’t know if will fix the problem.....but it defiantly cant hurt....Let me know if this helped cbinny1
Ive finally found the problem with my system :o)
Its not the subwoofer its the DVD unit!!! think outside the box.
Mine was randomly switching into headphone mode, so i pluged some headphones in took them out and walla its working fine.
Not sure why this happaned perhaps some dirt or something else got inside there????
Let me know if this helps
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
Laptop speakers not working on HP zv5000 laptop. Solution was to buy USB speakers - have two sets 1) http://www.amazon.com/Laptop-Speakers-Po...
the following has GREAT SOUND quality 2) http://www.amazon.com/Logitech-970155-04...
