My pen drive is not working properly it's pop's up that ur drive is write protected, to proceed remove ur write protection. but how to do that as i had not set it. plz help me.
(WARNING: After running this low level format tool, the whole USB flash disk surface will be fully erased. Therefore, data restoration will be impossible after using this utility!)
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
if u format ur pen drive. then use this step -
Check out the registry under:
1)click on start button 2)clik on run dialog box 3)type regedit 4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Some devices have a physical lock switch on the body of the drive itself. It may or may not be labeled as the lock. Switch it to the other position, and the write protection will be removed.
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
hi, could you mention the brand of the pen drive. anyway for deleting the files . try this--> right click the file and click properties. now check you "read only" (ie. dis-select it ) and select file or folder is ready for archive. now try to delete it. hope it helps. and after knowing your brand and model of your pen drive more information can be given.
sir, i am not able to delete files from my pendrive nor am i able to format. every time i try to delete or format, a window pops up saying that ur pendrive is write protected
