On bypasses you can either hook the parking brake wire straight to ground, if that does not work you can install a toggle switch between the parking brake wire and ground so you can mimic the parking brake on off.
run a jumper to GROUND from that lead. it must remain shorted all the time you intend on watching the dvd player. With that said, I have one in my car that is hooked up that way and I put mine on a toggle switch so that, in the event I get pulled over I can hit the switch and it won't work unless I pull the brake. If you get caught wacthing a movie while moving, there is a fine associated with it! just letting you know. but its very kool to have it on long trips.
I just spliced the brake wire into my cigarette lighter positive wire to provide the voltage necessary to bypass the parking brake requirement for video. Worked like a charm. It takes almost no voltage to bypass it. Even just licking your fingers and holding the bare wire allows video to show.
you mean the hand brake? so you can watch dvds on the move?
Have a look at the installation guide, if the sense is - neg.
put a switch inline to earth/chassis,.. you will then be able to FOOL the system into thinking the handbrake is on.
If you have navigation it may cause problems/disable some features.
The steering remote control input is for a wired remote control, or a third-party interface that allows you to adapt vehicle steering wheel controls to operate your deck.
Your problem is the parking sensor wire. This is supposed to be connected to your vehicle's parking brake switch. It detects when the brake is set, and will prevent a picture from showing when it's not set. The intent is to prevent you from watching movies while the vehicle is in motion.
If you can get a good look at the parking brake mechanism, you should be able to see the brake switch. Usually there's a single wire coming from the switch, which is built onto the parking brake mechanism. Connect your parking sensor wire to the wire coming from this switch.
