Compaq Amarda M700 Notebook Logo
Posted on Apr 03, 2009
Mouse problem on my compaq armada m700pc
When i turn on my lapetop the mouse is not there and when it do show up you cant move it it just float across the bottom of the screen what should i do.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
81
Points
First restart your laptop
then when you switch on the laptop the continuously move your finger on touchpad
check the mouse setting and change to mouse coursor moving high
Compaq Armada M 700 Owners Manual
The only thing I can think of is reduce the resolution on your screen to fill it. Go to start menu, click on control panel, click on display, go to settings, "top right" take your mouse and go to screen resolution put mouse on arrow and move one notch to the left click apply, a window will appear at the top asking if you want to save these changes click okay and you are done.
How will I know if my laptop Compaq Armada m700 is fully charged already?
Hi
You do not say which operating system you are using.
Right click on the toolbar at the bottom of the screen > properties > notification area > tick the Power under System Icons - Select Which Items to always show > Apply > OK > float the mouse on the battery icon to see % of charge and charge time remaining.
I hope this helps.
Compaq armada 500 (touch pad not working)
look at the ribbon/connector again, make sure it's not broken.
Sounds like a broken ribbon or bad connector.
Mouse problem
You should go to : Start -> Control Panel -> Mouse
and make settings as per your need and try out.
Thanks
Iqbal
1helpful
2answers
Mouse
I had the same problem with my compaq armada e500. I've been using an external PS/2 mouse for over a year and just now fixed the built-in touchpad buttons. In the mouse settings applet in control panel there is a setting for click speed. In Win 2k there is a little jack-in-the-box test icon. I moved the click speed slider to the slowest setting and my mouse came back like magic. I've searched and found lots of people with this issue, I can't say this is the only solution, but it certainly was easy. Of course, first I downloaded all the original COMPAQ Armada e500 notebookPC touchpad software from http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=96717&prodTypeId=321957&prodSeriesId=96231&swLang=8&taskId=135&swEnvOID=181
BTW, I appreciate the workarounds offered by posters here and on other tech support sites, but when someone wants to fix something, it doesn't help to say, "Oh, just give it up and spend money to get around the problem."
If you are still out there, dave, Instead of a USB hub, may I suggest (if you have the resources) picking up a PCMCIA card with at least two more USB ports? They are less than $100 and it really saved my neck when my onboard USB died. Don't be offended, but just in case you haven't noticed you have them, the slots are on the right side of your E500, just to the left of the headset and mic ports. The e500 has two slots and the cards come in different sizes for different laptops, but ours is (luckily) pretty standard. I bought my card at BestBuy.
Compaq armada m700 has a irratic mouse
go into your control panel and look in the mouse or keyboard Icon, Open it and look at your pointer properties. Set all to Default and see if that gets the mouse back and working right, If that still don't work try an external mouse for a desktop and see if it still acts erratic, If the other mouse don't work right there may be a problem with the hardware that operates the mouse actions. Let me Know if that gets you going in the right direction, Ok Thanks
2answers
Compaq armada m700 mouse is very irratic
did you try replacing the mouse? Or installed the mouse driver.
Compaq armada m 700 was not show battery no go with battery
In ur laptop,U click on Control Panel - Power options.Click on Power meter.There u select the battery show option.
I go for this web address.www.hpfashinontronics.com
U can Laptop skin order through online also.
My compaq armada 3500 wont boot up or only shows the welcome compaq logo
I think that has to do with the BIOS if it cant boot compeletly. Try pressing the key indicated to enter into SETUP if you cant just try and look for a jumper on the motherboard that is written CMOS it may be a button or something.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
