Dishwasher immediately errors on power on with tE.
Purchased service manual, replaced heater assembly (which contains the thermistor) = Still no go.
Purchased PCB replacement for part number 6871DD1006A which is 6871DD1006E. Hooked it up = still no go.
Not sure what to do next, besides service call.
Any suggestions.
Recommend that you closely check the water temp of incoming water. There is an error in some service manuals and if the inlet water temp is greater than 149 degrees (F) (some manuals incorrectly say 194 degrees), you could get an imediate tE error.
If that does not solve the problem:
_recheck_ the electric resistance of Thermistor.
(11~14k Ohms at 77 degrees (F) )
Good Luck!
The heater circuit has failed if "HE" is displayed. Discontinue use and contact a service technician. The dishwasher requires servicing.
"TE" means the thermistor has failed or the temperature of the water entering the dishwasher is over 194 degrees Fahrenheit. Turn the temperature down on the hot water heater in the home. If the error code reappears, replace the thermistor.
By the sound of this your heating system is malfunctioning and needs service.
If you need more on this let me know, but it is either your temperature sensor or your heating element or control board.
