I have a 27'' Magnavox TV. i unplug it and plug it back in and it automaticly turns on and goes into demo mode.
how do i get the TV back to normal use?
my tv will not turn off from demo mode. i unplugged it but still nothing.can you helpmy tv will not turn off from demo mode. i unplugged it but still nothing.can you help
AnonymousMay 24, 2009
My Magnavox tv is stuck on demo mode. HELP!!!My Magnavox tv is stuck on demo mode. HELP!!!
You can't post conmments that contain an email address.
My ancient TV/VCR Quasar combo had the same problem...and I don't have the original remote control. But holding down the "play" button for five seconds did the trick. Perhaps your TV is similar. I also read that holding down the "menu" button works as well. Hope this helps.
Many people are annoyed about demo mode coming out of nowhere and causing problems with many Magnavox televisions there is a simple process which will allow you to disable the demo mode.
Television must be turned off But remain plugged in
First You must place both your fingers on the VOL + and VOL - buttons on the television.
Then Turn on the television while still holding the volume buttons in for about 6 seconds..
The demo mode will now be disabled, Some televisions may turn off after demo mode is disabled just use remote to turn television back on or use programme up and down button on television to turn it on.
This will work even if you don't have the original remote as it requires no remote at all its a simple process and it will work with nearly all models of Magnavox televisions.
The tv has been accidentally set for "demo mode". Press the volume up and volume down buttons in front of the TV at the same time for about 5 to 10 seconds untill the demo disappears or sometimes the TV will turn off. You should regain control of the TV after this.
Those older Magnavox sets had a demo mode available from the on screen menu. Go to the menu and disable the demo mode, that will fix the trouble. When in the demo mode you will have no control over your set by remote or front panel controls. You can still address the menu though to turn off the demo mode.
I have exactly the same problem with a Magnavox LCD 42", very similar model 42MF437B/37. I don't have a solution. If you unplug the TV and plug it back it starts working, sometimes for hours, sometimes for less than 5 minutes, before it turns off again. Does anyone have any real solution?
