Display is going white. Have to restart phone every hour or two to see the screen. Parts are jumbled around and I can no longer read messages or navigate the phone coherently. All this after just over one year or normal use. Roommate has same phone and same problem.
AnonymousApr 13, 2009
my phone does that too. i dont know whats wrong with it. it may have been dropped too many times. my phone does that too. i dont know whats wrong with it. it may have been dropped too many times.
AnonymousApr 21, 2009
Mine does it too! If i have it up when i power up the phone then it turns white when i slide it down, if i have it down when i power up it turns white when i slide up.
Same Problem! Turning mine on and off won't work anymore either. Sometimes it will randomly come back on but if I slide it, it will turn white again. Help please! Same Problem! Turning mine on and off won't work anymore either. Sometimes it will randomly come back on but if I slide it, it will turn white again. Help please!
AnonymousMay 02, 2009
I have the same phone and the same problem. Mine only does it once in a while, but now it is getting to be a more frequent occurrence. I am thinking it is slowly dying and will eventually just be white all of the time. I checked the lower left corner of the area behind the battery to see if the square was red and it was white--meaning that the phone is not water damaged. So this appears to be something that happens to the phone over time. It is also related to the sliding thing so it could have something to do with the mechanism inside that makes the screen light up. If I open the phone really quickly (I mean as quickly as possible, not just casually sliding it) the screen never goes white. I cannot understand why that is.
AnonymousMay 09, 2009
my phone does the same. i turn it on, and if i have it slid up its fine. but then when i slide it down, my screen turns white :(
HELP! :( i love this phone.my phone does the same. i turn it on, and if i have it slid up its fine. but then when i slide it down, my screen turns white :(
AnonymousMay 24, 2009
same here. except now it is white all of the time. whenever i turn it on..whenever i slide it..all i see is white.
You can't post conmments that contain an email address.
Problem :- If your screen has turned white as shown in the above picture then you Samsung SGH-J600 phone has a problem with strip.
Strip connects the two parts of the phone.
And since we slide our phone many times we get this kind of problem.
Solution :- You need to replace the strip at a near by Samsung showroom. Note:- Don't try for other getting it repaired in unauthorized repairing shops for they also replace the strip for a cheaper rate but the life time will be very very small again the problem may repeat within 1 month.
I have got Samsung Plano 29 inch tv. I see redgreen and white color lines at the top of the screen.this slides down till the middle of the screen. Please suggest
just keep the phone slid up. i had to do that on my phone. and if i accidently closed it i waited til it went all the way black and then opened it again. or turn it off and on againuntil it works.
There is a fix. Ok so what you wanna do is power off your Samsung rant then you take out the battery and put it back in. After that you open to the slide pad and hold down the T and Y keys then power it on while still holding the 2 keys after the Samsung logo pops up then you can let go. Keep the slide keys open while it is powering on. You can close the slide pad when your screen shows up then it should be fixed. Well hope this works for you it worked for my moms phone when she was having this problem. Note: If your phone screen freezes or turns white again just redo the process.
yeah i also have a samsung m520, and its rececntly been turining white then back to normal. Its really annoying. I got it replaced last year with the warranty but now, about a year later, it turns white again. I went to the Sprint store and they said the cord that connects the screen and slider is either cut off or damaged. I like never drop my phone or in water, and its sucksss...
and i thought Samsung was reliable.
